Question about Yahoo Messenger
My yahoo messenger wont open so i try to uninstall it but it dosnt run it says CANT OPEN INSTALL.LOG. so what should i do? tnx....
  • rommel_gensa Feb 01, 2009
    hey bro.. tnx so much its already fix right now...
    tnx so much again....
    till nxt time bro...
    bye...
    tnx again
  • 80 Answers
Fastest way to fix this is to reinstall the same version of Yahoo Messenger by just running the installer again, uninstall, and then get a new version. Tell me if you need more help.
Posted on Feb 01, 2009
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
I can not open my yahoo messenger but i can open my email address
Hi.you may uninstall the program..after uninstalling it ... remove the folder yahoo from program files. then try to remove all the cookies in the temp. internet files
then try to remove yahoo registries using "regedit" command in run. then install it again from the yahoo site ..
if still dosnt work then may be u have to reinstall ur windows again coz there may have some .dll support files (which r stored by yahoo while installing in other directories like windows etc ..)
.dlll files me be corrupted .. so better reinstall ur windows
or restore ur PC to a backdate checkponit when ur yahoo was working properly ..
Jun 20, 2011 | Yahoo Messenger
Hi, i am having a problem trying to remoove yohoo messenger from add and remove programs, i get a message.,.could not open install.log file. my computer is now starting to low down.. confussed, ...
1) select Start->Run
2) click Browse button
3) find unwise.exe in Yahoo! install folder (usually C:\Program Files\Yahoo!\Messenger\unwise.exe), click OK in 'Browse' window
4) after that you should see in Run window the following:
"C:\Program Files\Yahoo!\Messenger\unwise.exe"
5) edit this line, so it looks like:
"C:\Program Files\Yahoo!\Messenger\unwise.exe" install.log
(after "the path" put the space and type install.log)
6) click OK in Run window
That should uninstall yahoo messenger.
Mar 11, 2011 | Computers & Internet
When I try to uninstall "Yahoo Messenger" there is message that says that I need to Open/Find Install.Log file. But the file is not in Windows XP. Should I try DOS?
First of all, DOS is an operating system on its own. It is not in Windows XP. Secondly, try running a search for the Install.log file. Without looking at the problem, I would say that it is just telling you that there is a log of the uninstall process. If it isn't letting you uninstall, run the search for the log file and go from there. Another approach would be to simply delete the Yahoo Messenger folder in the Program Files folder on the hard drive.
Jul 19, 2010 | Microsoft Windows XP Professional for PC
Cant open yahoo messenger
Hi! This error code relates mainly due to your action due to upgrade / re-install / repair of windows XP and to avoid this reinstall XP SP1a [service pack 1a] and immediately restart the system. have fine in all applications
Dec 21, 2009 | Yahoo Messenger
I was uninstall and install my yahoo messenger onto my computer but i cant open it,but i can open my mail,,what should i do?
Click Start button on taskbar click Run type chkdsk ....wait until it finish....Now try to run Yahoo messenger...
If that doesn't help clean your registry and re-install yahoo messenger....or uninstall yahoo messenger and delete the Yahoo! from C:/Program files/ and Install again new yahoo messenger from http://messenger.yahoo.com/download/winbeta
I think it will help you....Thanks for being with Fixya...Good luck
Nov 06, 2009 | Yahoo Messenger
Yahoo wont open
First open task manager....check if there is any yahoo messenger service running on services....click that and click End Process and now try run the proggy...again if that also not helps try uninstall the Yahoo messenger ...download and install new version....Good Luck
Sep 25, 2009 | Yahoo Messenger
Cannot find INSTALL.LOG
Try uninstalling using a program called Windows Installer Cleanup Utility:
http://support.microsoft.com/kb/290301
Install this application, and it will list the installed applications. Once you find yahoo messenger, highlight and select remove. The application will remove yahoo messenger for you, and should allow you to reinstall yahoo messenger.
Good Luck.
Jun 20, 2009 | Yahoo Messenger
"Could not open INSTALL.LOG file"
u can simply install old version again and uninstall it or u can try directly to install new version it will work dude.
Ahmad rabbani
Aug 21, 2008 | Microsoft Computers & Internet
Yahoo messenger
I cant uninstall yahoo because it says cant find install.log file I think I deleted it by mistake so what do I do?
May 11, 2008 | Computers & Internet
Yahoo Messenger Logo
559 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
