Question about Linspire Five-0 for Linux
IDE-disk not found on linspire5.0.59
Tried to download unbutu from unbutu.com it said errors and lins[ire said it cannot understand the file/program even though its a ISO , then the next day tried tostart my pc ran a redect and i saw at a glimpse a line saying IDE-DISK not found , then my decktop did not come up for at least five minuites and w window poped said that the protocol was lost, then other fatal errors as i was able to see while the redection going on, internet conection getting worse by the day and all the problems got worse after the attempt to downloading of the unbutu, i am getting close to get me a new pc and will never ever buy me any linspire system, anyone have their input ?
  • Roberta Smith
    Roberta Smith May 11, 2010
    is that a sata hard drive ?
  • 80 Answers
Linspire may have caused you to get a hard drive failure possibly. It may have one of the Linux bugs where it does hard drive seeks way too often and causes it to die out faster. These seem like the symptoms of a dieing hard drive.
Posted on Feb 01, 2009
What's your probleIM trying to install windows after putting in a new hard drive and I keep getting error 10e7160017
If this is a blue screen error and it do not let you to install the operation system ..but only loads a few files ..it means that you have let the hard disk set by default ..in BIOS and it is on sata bus..and needs to install the ahci driver ...If you have its original driver disk ..and you have a bootable disk with the operation system ..try to see if it takes the driver from a memory stick ...Just run the installation from the boot-able disk ..and press f 6 when it asks for 3rd party driver ..if you installing windows XP ..or ..when you get to the first screen on windows 7 ..choose to load driver and browse for the ahci driver on the usb stick ..if it can be found..or load it into a partition instead..or a external floppy disk ..Or ..make a boot-able memory stick .and load windows from it ..and use the original disk with drivers to load the ahci driver ..
In case non of these will work ..just go to bios settings first ..and under the hard disk 0 ..select to disable the ahci mode...and select ide compatible ..or ide default ..or plain ide...anyway ..just not ahci ....and the hard disk will be seen and will let you to install the operation system ..
If you are trying to install from a recovery disk ..it may not work ..cause will not recognize the hard disk and may need to use files usually stored in the reserved partition of windows..so ..best to try install from a boot-able disk or boot-able usb device ..and after that load all drivers and programs ..including antivirus..
remember to get the lan driver in handy ..cause without it you will not be able to connect top the internet and finish the drivers and programs installing ..
let me know if you solved the problem and please rate my answer if it's helpful ..have a nice day !
Oct 30, 2011 | Toshiba Satellite A105 Notebook
Trying to boot a d845pebt2 intel mb it came to shop with an error disk read error ran diag. and hd failed cloned drive to 320 gig old drive was 200 and got same error tried to run xp repair and got error...
as what i understand you have a failing HDD came from an old unit and trying to repair or reinstall O.S.? was your testing equip ment is the same as the harddrive you tried to replace and check. if it so. tried to replace the data cable of HDD you are using. and if you have another extra power supply try to test it with differrent PSU
Jul 13, 2017 | Intel Desktop Board D845PEBT2 Motherboard
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
File is not designed for your version of Windows
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
File is a virus, worm, or other malware file
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
Hardware incompatibility
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
I get a Blue Screen on my computer and the following: *** STOP: 0x00000024 ( 0x00190203, 0x82D7F008,0xC0000102, 0x00000000 ) What does this indicate is wrong? Is it memory faults or what? This was a sudden...
If you have the original Windows Install disk, you can boot off of that, choose the Recovery Console option, and once you are in the Recovery Console, run "chkdsk /r c:". The error seems to be a file system problem, so running a chkdsk could help or isolate the issue further.
Sep 29, 2009 | Dell Dimension E310 PC Desktop
Sony VISTA...operating system can't be found
download from the internet..
http://isohunt.com/torrents/?ihq=vista
you need to instal first the Utorrent downloader..
Sep 11, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Won't run. d3drm.dll not found error message
Get the file from here: http://www.dll-files.com/dllindex/pop.php?d3drm
when its done downloading copy this file into..  Main OS Disk (C:) > WINDOWS > system32.
When done, re-start your computer and run the program again. Hope i helped, Yuri.
Apr 25, 2009 | Broderbund 3D Home Architect Deluxe 6...
Error Message 'F:\ setup.exe is not a valid win32 application'
This issue can be caused by any of the below possibilities.
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
Bad file
Mar 18, 2009 | Computers & Internet
Linspire 5.0.59 cannot open unbutu
File format should be a . iso opened with power iso or120% unbuto need to be on a **** to run or boot from
Get it here http://www.ubuntu.com/
Jan 25, 2009 | Linspire Five-0 for Linux
About Eclipse IDE
just go 2 java.com and search for jdk there download it and install!!!!!!!!!!
Jul 24, 2008 | Computers & Internet
Faulty DFL-700 image - missing FWCore.cfg
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
Download Link:
http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
May 05, 2008 | D-Link NetDefend DFL-700 Firewall
Linspire Five-0 for Linux Logo
52 people viewed this question
Top Linspire Computers & Internet Experts
David Payne
David Payne
Are you a Linspire Computer and Internet Expert? Answer questions, earn points and help others
