How To Connect Two Hard Drives To One
Is There A Way To Connect Two Hard Drives Into One Without RAID?
Is There Software That Will Create A Hard Drive Out Of 2 Hard Drives.
How Do I Setup RAID And Do I Need A Special Device To Set It Up.
  • 80 Answers
You can do this with Software RAID. I dont want to take up a bunch of space and explain it but if you go here ( ) , it will guide through on how to do it. Its a pretty straightforward tutorial.
Posted on Feb 01, 2009
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
How do you re-initialise a drive, leaving data intact?
You're gonna have to reformat them to get rid of the raid information that Bios placed on them.
Jun 08, 2017 | Western Digital Caviar SE WD1600AAJS 160...
Didn't come with drives so now I need setrup raid
It looks as if this unit comes with raid pre-installed and does not have any downloadable software for it. One option would be to research Windows Software Raid which would be a "free" option.
Nov 03, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
2 drives - raid 0 - both went bad at the same time ; so i was told. i'm trying to reformat both of these on another machine -- they spin up and they each have a green led on the bottom side that sometimes...
you will have to use an operating system of some sort to attempt to format the drives. Wether it's a linux distro, Windows XP CD etc. If you boot from the CD during the install process you will be prompted to format the drive\
Oct 27, 2009 | Maxtor DiamondMax Plus D740X (6L080J4) 80...
How do i combime two hard drives to increase memory ?
RAM (Random Access Memory) are memory chips that the computer uses to run programming on the computer. This can be upgraded to the limit the computer will support, a good reference for capability of your system and a good source for purchase at
The Hard Disk Drive, is like a computer filing cabinet where you install programs and store data on your system.
I assume, you are talking about combining 2 hard drives to create more disk space on your system. This is done by setting up a RAID (Redundant Array of Inexpensive Drives) To do this you will need a computer that supports RAID or install a RAID controller and configure 2 or more drives to create an array.;wp_body
Oct 18, 2009 | Computers & Internet
Hi. my computer crashed a long time ago and I had to order some recovery disks but before I run them I want to backup the files on the drive but it has something called RAID (both 320GB hard drives only...
Well the drives are set to raid 0, if you're seeing 640GB. This implies that data will be stored on the first one till it's full and then move on to the next. If you have less than 320GB of data and you've lost drive 'A', then the chances of retrieving the data are slim. Your only options are then to try some recovery software or head off to a recovery company. Try running a diagnostic software on the drives individually to determine which drive is faulty.
Feb 27, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
About operating system
That depends on how you want to set up your system. If you want multiple hard-drives to work together as one, yes, you will need to load RAID drivers during startup. If you do not want multiple hard-drives to act as one large hard-drive then no, you will not need to load RAID drivers during startup.
I would not recommend loading RAID drivers if you only have one hard-drive. RAID is for two or more hard-drives in the same computer.
Feb 18, 2009 | VIA MSI K8M NEO-V K8M800 Chipset 800MHz...
M2N-SLI with Raid and Vista
Hi Eric,
You need 2 hard drives to create a RAID! (Read this).
Download from Asus the latest RAID driver software for Vista.
M2N-E SLI motheboard.
Hope you find this helpful Eric!
List any troubles or questions....
Jul 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Re-Synching problem with RAID5 Arrays in windows 2003 server
I beleave RAID5 needs all 3 disks to be present and maybe even on the same channels as they where set up for really id depends on the capability of your software or hard card. Good Luck!
Thank you,
May 21, 2008 | Microsoft Windows Server Standard 2003 for...
I needed to see your board & can at this site.
This is good for you as well. It shows me & you that your board can handel 4 each DMA/ATA-133 (Ultra) IDE Hard drives/ CD/DVD drives IDE-1Primary & IDE-2 Primary Slave. Each can run 2 IDE drives. Also 4 each Serial ATA SATA's. Two separate SATA controllers with integrated PHYs, each supporting two
drives in master mode. In your manual on pg.32 & 33 will help you to setup a RAID if you wish. Or you can also set the RAID to IDE which will allow you to use all your SATA hard disks as a single drive without setting up a RAID system. The site above supplies all your drivers needed & manual. If you need more help please let me know here.
Please vote......
Jan 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
