No image no message in my monitor and keyboard also not working. Not even post message
  • n7gtb Feb 01, 2009
    A friend brought her Gateway (GM5472) computer over with a very similar problem(?). No blue light on the front when powered on, but I can hear/feel the hard disk spin up...the cooling fans also spin up. Nothing on the monitor, no beep, no flash of led's on the keyboard and if I hold the power button to turn it off, there is no change... If you unplug the tower for any period and then plug it in again, there's a small spark like something is pulling a large current...(?)
  • n7gtb Feb 02, 2009
    Since it belongs to a friend, I don't know the exact behavior when it failed. Her (ex) room mate was alone while using it at the time and isn't offering much useful info... I Didn't notice any smoke or burn marks... Everything looks normal inside the tower, but didn't open up the power supply case. I did us a DVM to measure the voltages at the connectors (didn't unplug anything), and they all look pretty close (The +- 12 volts was just below 12 ...ie - +-11.7 to +-11.9) . This was with monitor, keyboard, etc all plugged in and running... Not too many repair shops in my area, but will make some calls tomorrow... Thanks for the assistance!
    Novelist:
    Scholar:
  • 64 Answers
Problems like this are usually best as a hands-on troubleshoot - I would have at a guess it's your power supply. Did you notice any smells or hot points on top of your computer as this happened?
If you got a power spike, there's also a good chance the processor (CPU) or mobo power regulator is had it.
Power supplies (PSU) can be troublesome to test and I would suggest you take the PSU to a reputable repairer who would be able to plug in a tester and tell you in an instant if it's ok or not.
Let's start with that and go from there - anything else you can enlighten us with about the fault or your findings?
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 02, 2009
Keep getting this message-Unfortunately, LG Keyboard has stopped. Everything else works fine
LG Keyboard has stopped - Android Forums at AndroidCentral.com
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
Jul 23, 2014 - 25 posts - ‎17 authors
My LG phone is displaying the message, "Unfortunately, LG Keyboard has stopped."... Only way around I've found is to use the android keyboard instead of the Lg keyboard. ... I have an LG optimus fuel (lgl34c) The" unfortunately the LG keyboard has stopped working" is popping up CONSTANTLY ... How can I fix Unfortunately, LG Keyboard has stopped ...
Jun 8, 2015
My phone says unfortunately,LG keyboard has stopped ...
May 12, 2015
LG Keyboard has stopped working?
Mar 12, 2015
Why does my phone keep saying the LG Keyboard has ...
Nov 24, 2014
More results from forums.androidcentral.com
Jan 01, 2016 | LG Cell Phones
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
WHEN TURNED ON, MACH MAKES A BEEPING NOISE EVERY SEC., LIKE A SEAT BELT CHIME. I GET NO IMAGE ON MONITOR NO RESPONSE FROM KEYBOARD OR MOUSE. FAN WORKS BUT NO RESPONSE TO MONITOR. IT DOES WORK WITH OTHER...
This is the beep error code. There are short and long beeps. Depending on the combination of beeps we may clarify the kind of the problem and possible errors. Please clarify me what is the bind of the beep combination (e.g. 4 short 1 long or1 short 2 long e.t.c.) From what you said up to now I can assume that the problem is either at one of the memory modules or at the vga card. Post me back details about the beep error code.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Dec 26, 2010 | E-Machines T6522 (RBT6522) PC Desktop
Lcd montor not working help
Symptom : No images on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power cord connecte properly.
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "Check Signal Cable" on the screen ?
Action : (Connected using the D-sub cable)
Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen (login screen), which can be seen.
Action : If the initial screen( the login screen) appears, boot the computer in the applicable mode (the safe mode for Windows ME/XP?2000) and then change the frequency of the video card.
Note : If the initial screen does not appear, contact the Service Center or your dealer.
Checklist 4 : Can you see "Not OPtimum Mode", "Recommended Mode 1440 X 900 60 Hz" on the screen.
Action : You can see this message when the signal from the video card exceeds the maximum resolution and frequency that the monitor can handle properly.
Adjust the maximum resolution and frequency that the monitor can handle properly.
Checklist 5 : There is no image on the screen. Is the power indicator on the monitor blinking at 1 second intervals ?
Action : The monitor is in Powersafe mode.
Press a key on the keyboard activate the monitor and restore the image on the screen.
If there is still no image on the screen, press the On button. Then press any key on the keyboard again to activate the monitor and restore the image on the screen.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 920NW Monitor
Switched from crt to lcd, no display!
You need to install the Display driver shipped or downloaded from net.
Mar 31, 2009 | Samsung SyncMaster 171 V 17" Flat Panel...
Gateway FPD1530 loses image shortly after powering up.
try booting into safe mode. press F8 while the computer is booting. see if everything stays normal. It should tell you that it booted into safe mode. Once there, change the resolution or the frequency of the display(also known as the refresh rate) by right clicking on the desktop and selecting properties. Once there, click the tab all the way to the right, it should give you color quality options and resolution options. At the bottom, there should be an advanced tab. Depending on our video card this menu can be different from others. Look in that new window for and option to change the refresh rate or the frequency. The value will be in xxx hertz. try setting it to 60 hertz.
Jan 31, 2009 | Computers & Internet
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
Lexmark 2500
Every time I try to run the scanner or open the imaging studio I either get a App4r.exe or Device Monitor application problem error message
postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK
Jun 22, 2008 | Lexmark All-in-One Printer with PictBridge
Mag monitor doesn't display bios post
The BIOS is sending the display information to the monitor but, when you turn your PC on, the LCD will be sleeping and it will take 1~2 seconds to wake up when receiving the display signal. The monitor is working and even if the BIOS messages aren't displayed, you can still press the correct keystrokes to get to the SETUP screen or press PAUSE in the keyboard to see what's going on in the POST.
If your LCD has a bicolor LED indicating the status (Standby/On) keep looking at it, when the LCD gets the video data, the LED turns instantly from amber to Green or blue even if the screen is still black. This way you can have an idea when the LCD gets the initial video signal and to press the keys accordingly.
Your PC will also delay the video output from the secondary video card because it's detected after the onboard card.
May 03, 2008 | Computers & Internet
No image on screen when boot up computer
check vga cable! check also video card on the pc!
Aug 16, 2007 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
410 people viewed this question
David Payne
David Payne
