Question about Epson Stylus CX6000 All-In-One InkJet Printer
Low Ink I printed 2 full size (8.5 X 11) pictures of "spiderman" for my kid and now I'm almost out of magenta ink but the rest of the cartridges are untouched. These were the only pix I printed so far but I may need some advice on if tyhis is typical after only 2 pictures and just out of the box
    President:
  • 2,976 Answers
If you are using the original ink cartridge, they anr not as full as replacements. If you get a refill kit, make sure it's compatible with your brand of printer. Generic ink is not all the same.
Posted on Feb 02, 2009
  • 80 Answers
Considering this is a high quality printer this is very well possible. If it was a spiderman picture it may have just used a lot of magenta for its color mixing. Print some regular low quality images not full size and see what happens to your ink. If your worried about high price ink you can visit a site where they sell 3rd party ink that is much cheaper.
Posted on Feb 01, 2009
The printer is suddenly reporting all ink cartridges are empty when they are not.
High probability of a main board electronics failure and/or waste ink chamber is full. It is probably cheaper and quicker to just replace the machine
Oct 01, 2017 | Brother MFC-425CN Multi-Function Center...
Epson 9800 ink magenta not printing after power cleaning
The separate print head is to blame. Needs replacement. Not cheap.
Aug 31, 2017 | Epson Stylus Pro 9800 InkJet Printer
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
HI, I have full ink cartridges, but magenta does not print. I have done cleaning and deep cleaning. The cartridges are fully unpacked (no tape over ink heads). There are no error messages, but no...
The ink may have settled and may be somewhat dry - shake the cartridge vigorously to loosen the ink and apply denatured alcohol to the print head nozzles on the cartridge - apply a generous amount and let it soak for a few minutes.
Jan 07, 2011 | Canon MP610 Photo All-In-One Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
New Ink Cartridges display low
yes it is not original you buy a new original one then show ink position
Jul 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Color
Recheck the placement of the ink cartridges. The black ink cartridge is larger; the cyan, magenta, yellow cartridges are all the same size.
When the ink cartridges were replaced, two or more may have been inadvertently switched or an extra yellow cartridge placed in.
Aug 04, 2008 | Canon BubbleJet i560 InkJet Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
