Question about Yamaha HTR-5840 Receiver
Buzzing on certain speakers (but not all)
Using yamaha htr-5840 amp, bose speakers (surround sound) and a vizio tv. this setup was working yesterday, switched entertainment centers and now when i plugged everything back in, my speakers are buzzing like crazy. is there a setting on the amp that got messed up? is it the speakers connecting to the back of the amp? how do i debug the problem?
  • 56 Answers
Do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Posted on Feb 01, 2009
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
Jan 27, 2014 | Yamaha HTR-5840 Receiver
Connecting Digital Audio to yamaha receiver
You've cabled it correctly. But on the TV there are settings for the Digital output, Off, PCM, and Dolby. Make sure you've set this correctly on the TV, and the Receiver.
Jan 01, 2014 | Audio Players & Recorders
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
Hi, I bought a Bose acoustimass 16 - 6.1 channel, iam curious to know which receiver is suitable for that.
I would get a receiver that puts out a little less power than the speakers can handle. This will prevent you from blowing them by sending too much power to them, but will still send enough power to make them sound good.
An example would be, if you're speakers have a combined power of 500 watts get a receiver around 495 watts or a little less.
May 03, 2011 | Bose Acoustimass 16 System
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
Jul 04, 2009 | Jensen CS10 Speaker
WE PURCHASED A YAHAMAHA HTR-6130 TODAY
You may need to set up the receiver for your speaker configuration. There should be a setup menu on the receiver, and that will allow you to tell the amp what speakers you are using, and what inputs you are connecting what devices to. You may also need to set your DVD player, cable box and TV for the audio stream you want to use. PCM or Bitstream to be more precise. Also make sure that the sound output is set to Dolby Pro Logic or Dolby Digital and the input signal is in stereo or surround.
Best Wishes.
Dec 29, 2008 | Yamaha HTR-6130 Receiver
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Yamaha htr-5940 with Acoustic Research wireless speakers AW877
use a 4 way splitter directly off the cable box 1 pair off cable to two out puts from cable box my setup works even tv is off I use it for music with tv off
Jun 03, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5170 amplifier shutting off & not powering up
I agree with Jango. Go back to the setup when it last worked. If adding the DLP is the problem, you may have some sort of a ground loop formed between the TV and the receiver. good luck...Rob
Mar 02, 2008 | Audio Players & Recorders
Yamaha HTR-5840 Receiver Logo
274 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
