Royal 1280MX Shredder Logo
Posted on Feb 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unit powers on, but the shredder tines won't run.
The unit will power on and you can her a click sound (sensor) when paper is placed in feed slot, but the shredding tines do not activate or turn. Not sure where the problem lies.
  • Anonymous Feb 16, 2009
    I had the same issue
Anonymous
Level 3:
Genius:
  • Master 1,218 Answers
  • Posted on Oct 19, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1218
Questions
0
Helped
288520
Points
1893
If you cant hear the motor running but you hear a click when you insert the paper it sounds like the eyes are ok so its likely the pcb thats defective...give Royal a call at 1-800-524-0799 for parts assistance.
No power. Seems to be overloaded
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Shredder stoppped working, no display or power when restarted. Power cable is good.
2answers
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
9helpful
2answers
Fellowes shredder only works in reverse
The unit sits on its own custom waist basket. In the unit is a micro switch that must be clicked by the seating of the unit on top of this waist basket. If the micro switch isn't activated, forward won't work. Check this. Short of this, the microprocessor that runs the diodes might not be working. (The diodes, one transmitter, one receiver, tell the machine the presence of a piece of paper in the slot.)
2answers
Only runs in reverse
This is an issue with the paper feed sensor usually located in the center of the paper feed slot. If it is mechanical you need to jiggle switch in and out to free possible interference behind switch (piece of paper or debris) if it is an electronic sensor you more than likely have a bad sensor or pc board. You will need to contact manufacturer for any further assistance.
1helpful
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
1helpful
Fellowes paper shredder
1helpful
2answers
Ativa DQ120D shredder
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Shredder runs only forward
Aurora AS1512X Cross Cut Shredder
Sounds like the cutter is jammed. Do you ever feed staples or clips in it? Will it reverse? If not, the power borad is burned out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Top Royal Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
