Question about Roper RGX4634KQ Gas Dryer
Roper Dryer won't spin.
I was doing laundry and took a load out the dryer. I spun it around with my hand to make sure there weren't any socks left behind and I heard a loud clicking noise. It was hard to spin and after the clicking it was quite easy to spin. I broke something off of the drum that held the belt in place. Everything else is fine it just won't spin. So I was wondering if the part that holds the belt is replaceable or should I get a new dryer? Also the part I broke off is at the bottom of the dryer under the drum. I cannot get to it.
    Scholar:
  • 42 Answers
From what I understand, it sounds like the idler "pulley" is broken. Upon receiving power to the motor, the belt inter-connects and ultimately drives and rotates the pulley and drum. The pulley is designed to guide and give "tension" to the belt when connected to enable the drum to "rotate and tumble".
The pulley is relatively simple to replace and can be purchased from your local appliance dealer for about $10 - $15. Depending on your "handy" skills, I would take the following steps to check your belt and pulley;
1. Disconnect the Dryer
2. Access the dryer cabinet/pulley by removing the front door (If your pull and clean fileter from top, remove 2 screws near filter. You may need a putty type knife to "slide and pop" the dryer open)
3. You may see the dryer belt already broken or disconnected, but take a look at the pulley and check for broken wheel, metal, chips/cracks, etc. Sometimes you may need to replace the pulley all together, but you may only need to replace the wheel part depending on the model of your dryer.
-Maintuniverse
Posted on Feb 01, 2009
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
Can I use dryer balls and/or dryer sheets in the kenmore steam dryer?
Instructions
Things You'll Need:
* Wool yarn
* Scissors
* Crochet hook
* Pantyhose or sock
Make the Core Ball
1.
Wrap some of the yarn around your fingers.
2. Take your fingers out of the loop you created and close the hole by pulling the yarn through it.
3. Wind yarn around the loop until you form a ball about 2 inches in circumference.
4. Cut the yarn attached to the ball using the scissors. Try to leave a little excess yarn dangling from the ball.
5. Grab the excess piece of yarn with the crochet hook and tuck it inside the ball to prevent the ball from unravelling during the felting process.
Primary Felting
6. Put the core ball into the pantyhose or sock, and tie the open end in a knot. (If you are felting more than one core ball at a time, you can separate them within the pantyhose or sock by twisting the fabric in between the balls before tying the knot.)
7. Put the pantyhose or sock containing the core ball into the washing machine with a load of laundry.
8. Remove the ball from the pantyhose or sock when the cycle is complete. It should now be slightly felted. To increase felting, simply repeat this process.
Enlarge the Ball
9. Wrap more yarn around the felted core ball to increase its size. It's all right if you make the dryer ball a little big at first, since it will shrink over time as you use it. A good initial size to make a dryer ball is around 9 inches in circumference.
10. Cut the yarn with the scissors once you have made the ball the appropriate size. Try to leave a little excess yarn dangling from the ball.
11. Tuck the excess yarn inside the ball with the crochet hook. This will prevent it from unravelling when in use.
Secondary Felting
12. Put the dryer ball into the pantyhose or sock, and tie the open end in a knot.
13.Put the pantyhose or sock into the washing machine with a load of laundry.
14. Remove the ball from the pantyhose or sock when the cycle is complete. The dryer ball should now be felted and ready for use the next time you do laundry.
Feb 28, 2011 | Kenmore Dryers
Hello: I have a tenant who is having problems with a GE Spacemaker washer/dryer -Stylemaster # is 622866-A. Here is how she describes the problem: ...it seems as though the washer isn't functioning...
If a spin and drain problem you can pull the front off to see if perhaps a small item (ie. sock or like size item) is stuck between basket and tub or in the drain hose? If it is a wash time problem that would be another direction.
Oct 06, 2010 | GE Spacemaker Washer and Dryer Electric...
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
I took lint filter out to clean it and forgot to put it back in, I started gas dryer and it stopped, I believe there is a sock stuck in there somewhere. Does the front come off and what do I need to take...
Hello Kims987K,
You may want to check circuit breakers in your Breaker Panel to see if the one for your Dryer is tripped, and reset it if it is. Even though you have a Gas Dryer the Drum still operates on electricity, so without it the Dryer wouldn't function at all.
I don't think that the sock is stopping your Dryer, as the lint filter just filters lint from your Dryer's exhaust. So, even with the lint filter out a sock couldn't fit through the small holes in the drum that ventilate it (that's how the lint gets to the filter). I guess there could be a switch that detects whether the filter is in the machine and cut it off though, so you may try to re seat the lint filter (replace the lint screen/filter making sure it's in all the way), and try to start it again. If you look inside the Drum and see any way that a sock or anything else could get out other than through the door opening? That would be a problem.
If the filter was missing for several loads of laundry? Then you could have a restriction in the exhaust causing a thermal overload circuit to cut it off too (prevents the Dryer from catching fire). Does the light come on in the Dryer when you open the door?
From the information you posted, all I got is that it's a Gas Dryer that won't run and you appear to be missing a sock, so more detailed information will probably help in finding your solution.
I'll check back, and Good Luck finding that sock.
Mar 05, 2008 | Dryers
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Roper RGX4634KQ Gas Dryer Logo
611 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
