Question about Aircat Silent Power 3/4'' Air Impact Wrench Gun
Air wrenches are noisy. Aree all air wrenches equally noisy?
Can we buy a quieter brand? Is there a "silent air wrench" being sold?
    Problem Solver:
  • 10 Answers
No, by design there is a hammer hitting an anvil inside the tool. There is no way to make that quiet. If you want quiet you will have to use hand tools.
Posted on Feb 09, 2009
Where can i buy "block ca141848" for cp air wrench 734
You can try ereplacenmentparts.com
Follow this link and they a picture of the parts that you are looking for! Block CA141848 for Craftsman Power Tool eReplacement Parts
Hope this helps.
May 30, 2014 | Chicago Pneumatic 1/2" Air Impact Wrench
No power at all
you should be able to order a rebuild kit thru the company that made or sold it
Jan 22, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
Oiled and still runs slow
Vanes in the air motor not sealing well
Aug 01, 2011 | Ingersoll Rand 1/2? Heavy-Duty Air Impact...
Question there are four settings on the air impact wrench 119106 I need to set to specific foot pounds are each of the four setting equal to a specific foot pound per inch (ie: setting one is 50 pounds...
if you dont use hand tools often you should never trust the torque from impact wrench you should always recheck with tension wrench for correct torque specs
or at least hand tools such as breaker bar, spanner, ratchet
depending on what your doing up and diameter of bolt or studd for what application
Feb 06, 2011 | Craftsman 1/2" Impact Wrench
My brother passed away and i was left his tools. I have a Craftsman Model 875-71229 Air Impact Wrench, but no manual. I do use tools, but as I'm not a mechanic, I was thinking its probably of no use to me,...
The Chicago Pneumatic air wrench is not the same as the Craftsman, but it's a good brand.
Probably you could sell it if you have no use for it yourself. The impact wrench would have been used to remove lug nuts or other fasteners on an automobile, most likely.
Good luck on deciding what to do with the items.
Dec 06, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
My Aircat 1404BG impact gun stopped working.
most of the problems accure from being dry try 2 or 3 drops through the air intake fitting every so often depening how much you use your air tools, it may be time for a new one but i would try the air tool oil first before bying a new one, i hope i helped.
Jan 02, 2010 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Where can I buy parts for a CP722 air wrench
from any Snap-on tool dealer or MAC tool dealer, u can also order them direct from manufacturer web site, have this gun myself.
Aug 07, 2009 | Chicago Pneumatic CP7750 1/2" Air Impact...
Wrench Troubleshooting
In line oiler Lubrication is critical to extending the life of your valuable air impact wrench and increase productivity. An air tool that has not been properly lubricated will result in low power output. The usual culprit is a dry motor starving for some oil. Your impact wrench is an expensive investment and you must take the time to properly lubricate it. The easiest and quickest way to make surein line oiler it is constantly lubricated is to install an in line oil lubricator. One of these will insure your air tools are receiving oil every time they are used. In line lubricators attach right into the air hose and you fill them with the correct lubricating oil. (see your manufacturer's specs.). You should also do routine external lubrication through the hammer case grease fitting. A well lubricated air impact wrench will deliver more torque, last longer, run quieter and increase productivity. Don't forget to add an in line oiler to your next impact wrench or air tool. It will pay for itself several times over.
Aug 27, 2008 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Wrench Maintenance
Aug 27, 2008 | Campbell Hausfeld Maxus 3/4" Impact Wrench
Portable Air Compressor Comparison
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
Aug 27, 2008 | Acme Automotive ACMA680CS Typhoon High...
Aircat Silent Power 3/4'' Air Impact Wrench Gun Logo
133 people viewed this question
Top Aircat Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Aircat Tool and Hardware - Other Expert? Answer questions, earn points and help others
