Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 (52"HDTV)
I have a RCA 52" HDTV bought new 3/2005.Today it acts up for the first time.When you turn it on it takes about 5-10 seconds for the screen to come up ,as it always has.the screen is solid green no pitcure or sound.After about 3-5 seconds the screen will flicker a couple times you here a pop sound deep inside and the tv powers down (off).You can turn it back on and the same thing.The power button light is green the whole time it 's on. Please help,thank you.
  • thrash4 Dec 15, 2007
    my RCA 52 stoped coming on, at first when you turend it on it took longer then it should then it just got worst the time it took got longer. now it will not come on at all the green off and on light blinks but that is about it.
The common culprit for this problem is a defective Focus/Screen control block. It is located behind a removable panel in the front under the speaker grill. It is a little black box mounted up along the top of the opening with two rows of three openings for adjustment of the Red, Green and Blue "focus" and "Screen" (brightness) settings. They often get contaminated with dust which is attracted by the high voltage flowing through this block. It is held on by a single screw and has 9 push on/off wires into the back of it. The replacement is fairly straightforeward, just keep track of which wires go where. Leave the set unplugged and powered down for a day or so and the voltages should all have bled away to ground by then.
Posted on Oct 04, 2007
SOURCE:
I HAVE A 52' RCA HDTV THAT WILL NOT TURN ON ,AT TIMES IT SEEMS LIKE IT WILL TURN ON BUT THEN GOES BACK OFF,CAN ANY ONE TELL ME WHAT THIS PROBLEM CAN BE
sounds like the power caps CP150 CP120 and CP114 on the deflection board. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit also comes with instructions.
Mar 15, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA big screen won't turn on, it clicks 3 times and then nothing. I have sat there for an hour and it has turned on with me continually pressing the on button every 45 seconds. But today it would not...
Bad Capacitors on Deflection Board CP114 ,CP120, CP150 2200uf 16v use 25v. other 2 caps are 220uf 35v
Deflection board is bottom left hand side Board,has FBT flyback transfomer
Oct 03, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Will not power on and stay on
Problem is with the IC.Picture tube is OK.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV R52WH74 TV WILL NO TURN ON
I would contact RCA support, and they should be able to provide you with the authorized RCA service centers in your area.This is the RCA customer Service number 580-634-0151
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
128 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
