Question about Acoustic Research AR PR1212 Subwoofer
Acoustic Research Subwoofer cuts out
I have an Acoustic Research PR1212 subwoofer, it will not go into standby mode and it now is shutting down during high impact events in movies.The blue standby light will go out and no sound for only a second or two and then it comes right back on. I thought about bad connector on the end of my monster cable but I have another one and tried it, same thing happened. If I turn the volume down on the sub then it quits doing it, but I would think I should be able to turn it up past 1/4 volume. Not blowing fuses, just shuts down when it shouldnt and stays on when theres not any signal. Thanks
  • Anonymous Mar 04, 2009
    I been having the same problem about it cutting out at high volumes, but mine goes into standby mode after inactivity with no problems. I have a friend that is going to help me figure out the problem with the amp, but we have not had a chance to work on it yet. I will post again if we are able to figure it out.
5 Suggested Answers
  • 3422 Answers
SOURCE: Acoustic research subwoofer s108ps has a burnt capacitor
HI,
I'll let you know if the service manual is available for this model.
Posted on Jun 15, 2008
JigSaw007
  • 157 Answers
SOURCE: Acoustic Research AR1 HiRes subwoofer amplifier
hello sir
Posted on Aug 25, 2008
SOURCE: Hello, the auto on on my acoustic research pr1212
No sound from sub, pilot light on, distortion only from volume control when rotated, fuse good. In the past, rotating or jiggling of volume control would correct problem
Posted on Sep 13, 2010
dunnbiker
  • 8546 Answers
SOURCE: I just got a Acoustic
What makes you feel that isn't right?
You can't just slap a sub onto a receiver and have it work optimally (if at all). The receiver must typically be configured to know it has a sub, then bass managment and sharing decisions must be made, then crossover frequency choices and levels adjusted to match it all up.
All self-powered amps work that way.
Have you looked at the manual for your JVC?
Posted on Apr 17, 2011
I need manual of acoustic research hc5 sub
this one really strong so you can easly use this
May 16, 2012 | Acoustic Research S112PS Subwoofer
I just got a Acoustic research S108 PS subwoofer from a friend. No instruction manual. I'm wondering how to connect this to my stereo system. I have an old JVC amp with a out RCA jack marked SUBWOOFER, but...
Apr 17, 2011 | Acoustic Research S108PS Subwoofer
The capacitor for the subwoofer AR S108ps burnt where can i purchase one from?
http://www.parts-express.com
check this site out i think you'll find what you need there.
Nov 06, 2010 | Acoustic Research S108PS Subwoofer
My AR-S115PS Subwoofer keeps cutting out. Especially at high volumes. I've never had this problem before. What should I do?
check your speaker impedance by multimeter normally speaker ohms range from 8,6 or 4 ohms see your speaker spec. possibility speaker short, so impedance become too low when driving with strong bass become over current and cut out. if this is the problem the only solution is change the speaker only.
Oct 25, 2010 | Acoustic Research ARS115PS Speaker
Hello, the auto on on my acoustic research pr1212 doesn't work anymore. The unit just stays on all the time. It used to sense the signal just fine, but now it just stays on and I have to manually turn it...
Are you certain it isn't sensing a signal all the time? Disconnect its inputs first to prove it.
If you feel compelled to monkey with it, I'd start with the state of the Auto switch. It might be asserting "ON" instead of "Auto"
Apr 06, 2010 | Acoustic Research AR PR1212 Subwoofer
Sub keeps loosin bass
Its probably not your subwoofer- its likely that your amp is showing its age after 2 years of bumping -But it could be that you have partially roasted the coil on the sub which is tripping your amp into protect mode-thus shutting down throw a different sub in there for a week and listen to it and if it stops acting up then its probably the sub if it still shuts down then it may be time for a new amp
May 29, 2009 | Fusion FEW12PK Car Subwoofer
How do I connect my AR subwoofer to the tuner?
If your tuner has a sub out you use that together with a single rca cable for the signel
Jan 02, 2009 | Acoustic Research S108PS Subwoofer
Acoustic Research ARS115PS Subwoofer, No Sound
I have the same problem with the smaller AR 112PS speaker and since Acoustic Research went out of business, I too have been looking for a solution. I may have found an alternative to throwing away this really nice speaker. I found a company on the web that appears to sell an amp that may fit nicely into this speaker enclosure for $99.00. Check it out...
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&PartNumber=300-805
Tenderfoot56
Feb 27, 2008 | Acoustic Research ARS115PS Speaker
Acoustic Research AR PR1212 Subwoofer Logo
180 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
