Question about Maytag MZD2766GES Side by Side Refrigerator
No water coming from dispenser on Maytag MZD2766GE
Ice dispenser is working fine. Can't get no water for some reason?
  • Anonymous Feb 21, 2009
    I have Maytag MSD2254VEA, water dispenser just hums but ice works fine. Only 6 mo old.
You should defrost the freezer. The water line coming into the freezer is frozen and the water can't get through the little tubing.
Posted on Mar 10, 2009
Maytag MSD2756GE ice maker issue. makes ice fine. While dispensing water in the door, it also fills the ice tray at the same time. Water comes out ice fill tube AND door. If no water is called for at the...
This is an odd one!The water control valves has separate sets of wiring that travel through the dispenser control board. That gives an opportunity for strange things to happen as mentioned in your post. If you haven't replaced the dual water control valve and put the wires back wrong the next thing will be to test the 61005274 Dispenser Control Board
If you have a OHM meter and a voltage testing meter I don't mind helping you to test the wires and 61005274 Dispenser Control Board I can send you to a link to view the wiring diagram and walk you through the diagnostics. Let me know, Thank you, John T
Appliance 911
Contact Me Here
Apr 27, 2014 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
My Maytag MZD2766GE dispenses water but does not make ice
check water valve, also your water line for ice maker could be frosted that happen always, but reason is bad water valve....
appliancesrepairla.com
Jul 01, 2010 | Maytag MZD2766GES Side by Side...
Our ice maker stopped working. there is water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfdjdfh
May 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
I have a MZD2766GE that does not crush ice
There are several test that can be done to insure the lever that switches the cubed ice to crush ice in the Service Manual for your model Click Here=> MZD2766GE section 3-10 at bottom of page and in the scroll at top of page you will go to page 58 to begin. Once you have the manual saved to your computer and have questions you may ask as we both follow along. There is a solenoid that is supposed to raise and lower the crusher lever. Test by taking the ice bin out and pressing the door light switch it to insure the dispenser panel will activate. Then press the auger and crushed ice. The solenoid that I am referring to is part number Click Here=> 61005253 If for some reason the solenoid is bad, rusted or has no voltage the crusher lever will not activate. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 17, 2010 | Maytag MZD2766GES Side by Side...
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Dispenser not responding
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Aug 16, 2007 | Maytag MSD2754G Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
246 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
