Question about Frigidaire PLEF398AC Electric Kitchen Range
Frigidaire cplef398ccb Flashing F7
My range clicks when I touch the door, it sounds like relays clicking. Would that indicate that it is the EDC that needs replacing, I had origanally thought it was the EOC?
Thanks
  • 360 Answers
Version 1 of your unit F7 error code.
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
This does not mean that this is the problem but it is where I would start. EDC is less than a fouth the cost of the EOC.
Please take the time to rate this solution
Thanks,
clarkco
Posted on Feb 01, 2009
Kenmore wall oven digital screen is blinking F7? it has a digital button screen. i can clear it but it comes on again a minute later. no other buttons work?
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
Oct 19, 2010 | Kenmore Ovens
I have a Kenmore built in oven, it doesn't work. There is a code F7. What could that mean?
Hello there:
Oct 05, 2010 | Kenmore Ovens
Need to know if my battery or starter is bad, or both. origanal 96 starter, gel battery 6 yrs old. clicks when trying to start, lites do not dim at all just clicks fast . 1996 harley sporster
I would lay odds on the battery if it's six years old but that's guesswork, I prefer mechanics. Take the battery out of the bike and take it to an automotive parts house. Ask them to check the battery with a load test. That will tell the tale.
If the battery is good, what you may be hearing is the starter relay clicking. Since your lights are not dimming, the starter is not even being engaged. The starter relay is a one inch cube device usually black in color. On your '96 model, I think it's on the backside of the oil tank. You must take the seat off to see it. Try to start the bike and see if that's what is making the clicking sound. If so, replace the relay. Check these two things before you go replacing the starter. Starters aren't cheap.
May 27, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
Frigidaire electric oven has F9 error message. Door will not open, tried to do self cleaning and it never cleaned, never got hot. Just blinking light on door lock.
HI There OK i see what you saying so im sending you this to help you. I hope this get's you in the right direction.Lock motor relay watchdog is active when it should be off Microprocessor checking the operation of the EDC lock relay after self clean is selected, relay failed. Replace EDC.
Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Ovens
1997 Range Rover Window Stuck
There may be another relay in the drivers door for the automatic touch feature. If you also have a switch on the drivers door follow the wires down to this second relay. If you don't have a second relay then try to jump the wires at the door to power the motor in both directions. If you can do that, the door switch is bad on the "up" terminal.
The regulator can be broken and you can see that with the door panel off. The motor terminals may have corrosion and you can probably reach that plug with the door panel off.
Jul 21, 2009 | 1996 Lincoln Continental
Range led flash code F7
Here is the error information for Fault Code F7
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
I would replace the EDC
Feb 01, 2009 | Ovens
After cleaning MER6775AAB, upper oven has stopped working
See if the top heating element is open. Also check the switch that feeds power to the element.
Aug 28, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Code F9
Dec 15, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
983 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
