Question about Motorola AXU4100 (10 Channels) 2-Way Radio
Motorola AXU4100 talkaround mode
I need help!!! how do i put my Motorola AXU4100 in talkaround mode???
  • Motorola Master
  • 1,654 Answers
One of your programmable buttons, A, B, C or D, should be programmed for the TalkAround feature.
The options are:
Nuisance Channel Delete
PL/DPL enable (on/off)
High/Low Power
Volume Set
Scan
TalkAround
The buttons can be programmed for 2 features, both a long and a short press setting.
Posted on Feb 02, 2009
I am trying to program a xpr 4550 with a talkaround channel that is the same feq as a repeater channel with no luck.
Be sure "talkaround" is enabled on the code-plug, then use the "direct" or "talkaround" button on the front panel.
Jan 28, 2014 | Motorola XPR 4550 Two Way Radio
How do you set the radio back to default settings. AXU4100
  • HI, I can help.
  • You will have to contact an authorized Motorola dealer such as http://www.buytwowayradios.com/products/motorola/motorola-ax-axu4100.aspx or any reputable two way radio store in your area. Those radios are still very programmable. I wish there was some way around this but there is not and Motorola gets very grumpy when unauthorized people end up with their interface because it is in fact quite the money making racket.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Motorola AXU4100 (10 Channels) 2-Way Radio
Motorola AXU4100 - just flashes and beeps after startup, all lights blink on screen and beeps.
You either have a bad or defective battery, or the radio is in need of service. Try a battery from a known good unit and see if the problem disappears. If so, simply replace the battery. Otherwise, your radio will need serviced by a Motorola dealer capable of repairing the AXU style radio. (typical flat rate repair on this style unit is $69)
Best regards.
May 23, 2011 | Motorola AXU4100 Two Way Radio
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
I have a motorola AXU4100 radio. Every time I use it to talk it shuts off.
It is likely your battery pack is not fully charged or it is in need of a new battery. It takes more energy to transmit than to receive. Pressing the PTT uses quite a bit of power and will easily shut down a radio needing a battery (or charge). If you feel you battery is still good (less than 2 years old), you might check your charger to see if it is functioning correctly.
Best regards.
Jun 11, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
What version of software (CPS) is needed to program the Motorola AXU4100 portable radio?
RVN4196 CPS (Motorola proprietary software subscription) which also does the Radius CP125.
Sep 30, 2009 | Motorola AXU4100 (10 Channels) 2-Way Radio
Forgot how to get the VOX working on AXU4100
The AX series did not have VOX capabilties. Here is a link to the Owners Manual for the Motorola AX series two-way radio.
http://www.hitechwireless.com/pdf/AXSeriesManual.pdf
Mar 29, 2009 | Motorola AXU4100 (10 Channels) 2-Way Radio
Motorola AXU4100 2-Way Radio Problem
Have the radio reprogrammed at your local Motorola shop.
May 30, 2008 | Motorola AXU4100 (10 Channels) 2-Way Radio
AXU4100 Manual or help
On a Motorola AXU Series (including the 4100):
1. To unlock, press the “D” button for about a second or until the circle is gone. The circle with the line thru is the keyboard lock indicator;
2. To change channel, you need to press either the arrow left or right in Normal Mode;
3. To change PL (assigned to a channel), don’t think this can be done by the user
4. To change Ch. 1 from 464.500 MHz (PL-67.0) to 463.525 (PL-136.5), don’t think this can also be done by the user.
Even the built-in Programming Mode Parameters do not have this option to change assigned frequencies and PLs. An external programming software using a PC may or may not allow this.
These radios came pre-loaded with its channels assigned with specific frequencies/PLs. As used in a Motorola AXU411, they are:
Channel Frequency PL
1 464.500 67.0
2 464.500 77.0
3 464.500 88.5
4 464.500 179.9
5 464.500 None
6 464.550 67.0
7 464.550 82.5
8 464.550 94.8
9 464.550 179.9
10 464.550 None
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 24, 2007 | Motorola AXU4100 (10 Channels) 2-Way Radio
Motorola AXU4100 (10 Channels) 2-Way Radio Logo
484 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
