Question about Konka K1398U 13" TV
Don't know how to re-program. Lost tv channels. Lost manual
Model Konka KK-Y2378
Family will be very happy if I can fix this!!
3 Suggested Answers
  • 139 Answers
SOURCE: I have a Konka KLC-1508U television and want to
You will need a Digital Tuner for this TV. You can find them most anywhere for about $40
Good luck
Posted on Dec 30, 2009
charleshucke
  • 1114 Answers
SOURCE: Hi! I need the code/s to program a Konka TV using
I could not find the code listed for the Konka brand, but that does not mean that you cannot use the remote. Here are some real easy instructions on how to perform a code search with that remote for that television. I had to do this for my sister just a couple of days ago.
I hope that you have found the information that I have provided helpful as that is my goal.
Auto Code Search and Entry If your component's brand is not listed in the code tables, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Auto Code Search method below. The remote will cycle through all of the codes, in the event that your code is listed under another brand. The Auto Code Search method may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand appears in the code lists you should try first the Direct Code Entry method described above.
Step 1: Manually turn on the device you want the remote to control (TV, VCR, DVD, cable box, etc.).
Step 2: Press and hold the device button (TV, VCR, DVD, etc.) you wish to program. The illuminated ON/OFF key turns on and remains on.
Step 3: While holding the component button down, press and hold the ON/OFF key. The illuminated ON/OFF key turns off.
Step 4: After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 5: Release both keys. The illuminated ON/OFF key remains on.
Step 6: Press and release the PLAY button, then wait 5 seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every 5 seconds until your component turns off. Each time you press the PLAY key, the illuminated ON/OFF key blinks and a block of ten codes are sent to your component. This process continues until all of the codes have been searched. If your device has not turned off after all codes have been searched, the illuminated ON/OFF key blinks 4 times and turns off. The Auto Code Search Entry method is exited.
Step 7: When your equipment turns off, you know'll that the correct code is in the last block of 10 codes sent. Press and release the REVERSE key, Wait 2 seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE button every 2 seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON/OFF key blinks.
Note: If you accidentally press the REVERSE button after your device responds, press and release the FORWARD key. Wait 2 seconds to see if your component turns off again.
Step 8: Once your component turns on, you have found the correct code. You must save the new code by pressing and releasing the STOP key. The illuminated ON/OFF key turns off.
Important: You must press the STOP key to save the code or the correct code will not be stored!
Posted on Jan 15, 2011
Testimonial: "THANKS a lot Charleshucke; IT WORKS... ;-)"
Universal tv remote control code for konka KK-Y26IN
Hi, this Konka remote is not a universal remote and cannot be programmed to any devices. It only works with the original Konka TV. To purchase a new Konka remote for you Konka TV you can go to Replacement Remotes.
Oct 06, 2012 | Universal Remote Control Remote Control
Channel search problem
The mains system memory IC to your TV has damaged. Replace it.
Aug 12, 2012 | Konka K1938U 19" TV
I need to purchase a new remote for my Konka TV model KDL32FS62U. The remote I'm replacing due to damage is a KK-Y319A. Any idea where I can find a replacement remote?
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Find out codes for Konka from the code list provided by this site. Pull up older posts there. Buy one universal remote control, which has setup codes for Konka described above. all setup proceedings also described.
May 14, 2012 | Televison & Video
Have a RCA 312 WR universal remote,need programming code for a Konka tv. Lost list that came with remote
You can view all the documentation (including code lists) here. Don't get your hopes up though, as according to the manual, there is no listing for a Konka TV. If you meant to say you need a code for a Konka DVD Player, you're in luck - it is 30711.
I hope this helps and good luck!
Jul 04, 2011 | RCA RCR312W Remote Control
Reception has gone down from about 50 to 13 channels on my konka. remote marked with kk-y217 mcccutchj@bellsouth.net
The tv is probably the old analog tuner type, so you will now only receive analog channels and not the new digital ones.
Oct 25, 2009 | Televison & Video
How to unlock my Konka K2001UM TV
check the tv's manual to see if there is anything about a "Child" or "Button Lock" feature.
Jan 16, 2008 | Konka K2001UM TV
Konka 32" LCD/HD TV
contact Konka directly in Calif. e-mail them
Oct 16, 2007 | Konka K2001UM TV
Konka K1398U 13" TV Logo
80 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
