Question about Refrigerators
Frdge keeps tripping the earth linkage
Fridge will cut and throw the earth linkage switch have checked the compressor and all checks out OK
  • 700 Answers
Have you checked the defrostr heater yet? Take and advance the defrost timer until iits made and then check the heaters.
Posted on Feb 01, 2009
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections
it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
Jun 08, 2017 | Whirlpool Refrigerators
Samsung Fridge keeps tripping main electricity?
This needs a serious check up as it is possible that the compressor motor is drawing inmore current than required. Also check if the capacitor had failed.
If the trip is a ELCB then check if the earth connection( ground) is poor and so the circuit breaker sensing external voltage will trip off.
Use a clamp testor to measure the starting current of the motor to confirm.
Jul 25, 2011 | Samsung Refrigerators
Freezer working fine, fridge not cooling. Left to defrost last night, turned back on this morning and all seemed fine. Fridge was cooling and seemed to be running all ok. Tonight the earth leakage keeps...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Fisher and Paykel E522BRX Bottom Freezer...
Hello there fridge keeps tripping power every time i switch it on
If random then the compressor has earth leakage when under load. Compressor is faulty. If water flow is disrupted and water filter light comes on for replacement for ice maker/cold water then this can cause an earth leak that will trip the rcd
May 28, 2010 | Max-Fridge STC55926 / STC55927 / STC55928...
Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Mar 11, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Suddenly tripped off house
Hi akula, 200 ks to a fridgie, LG appliance, you must be in Australia;) Is it the earth leakage circuit breaker operating. If so, then you have a leakage problem to earth from the heater pad(not quite sure what that is, but this problem will need to be repaired. Am doing some research to see if there is anything that can be done without just getting a new fridge. Back to you soon.
regards
Graeme
Mar 21, 2008 | Refrigerators
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
