Question about Canon PIXMA MP150 All-In-One InkJet Printer
Ink cartridge hi, anybody could help me pls... the ink cartridge on my printer on the right side is not in place, its like it turn up side down and i dont know how to put it in place. i dont know how to open that side. my sister tried to replace the ink and she did it by mistake touching that side. now, its not working, everytime i turned it on it says E 2 4. what does it mean? hope u could help me, and thak u very much
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12764 heres the link just type in ink cartridge and it gives you step by step With pics.
Posted on Aug 01, 2007
SOURCE:
How do you insert ink cartridge?
hi may.
you have not said on what printer.
but go to this link might help you out.
Remove the old ink cartridge and install the new ink cartridge.
  1. Make sure the printer is turned on. ...
  2. Open the top cover of the printer. ...
  3. Wait until the carriage moves to the right side of the printer and is idle and quiet.
  4. Press down on the old ink cartridge, and then slide it out of the carriage.
More items...
Replacing Ink Cartridges - HP Support
How do you insert ink cartridge Google Search
Nov 06, 2017 | Office Equipment & Supplies
I have epson DX7450 tells me ink out replaced all but still ink out report have don eall the books operation guide please help regards B D
Check whether cartridges is placed properly ?
Unplug the unit for 30 minutes and plug back the power chord to the unit .
Nov 01, 2008 | Epson Office Equipment & Supplies
How do I install my ink cartridge for a hp officejet 4215 all in one
Turn on the HP printer. Lift the printer cartridge door, which is the right side of the printer, revealing the black and color ink cartridges. Push down on the front of the cartridge you need to replace and pull it out slowly. Unwrap the new ink cartridge and peel off the tape. Insert it at an angle into the cartridge slot. Apply gentle pressure until it clicks into place. Close the cartridge door and press "OK" when prompted.
References:
HP User Manuals: HP Officejet 4215
Hope this helps you :)
Mar 07, 2012 | HP OfficeJet 4215 All-In-One InkJet...
Where is the toner cartridge and how do I find it?
Plug the Lexmark 2600 into an electrical outlet and press the power button. Allow the unit to power up. The power button will turn green when ready.
Turn on the Printer and Open the top cover of the Lexmark 2600 by lifting the cover upward. you will find all cartridges down there.
Now you see how to replace them
Remove the black ink cartridge from it's packaging. Remove the tape from the black ink cartridge first and place the cartridge into the left ink cartridge holder. Press the cartridge down into until you hear it lock into place. Close the ink cartridge holder lid by pressing it down firmly. This secures the ink cartridge in place.
Remove the colored ink cartridge from the packaging and remove the tape from the cartridge. Place the cartridge into the right cartridge holder and press down until it clicks into place. Push down the cartridge holder lid.
Close the lid of the Lexmark 2600 and allow the print cartridges to align. The power light will be blinking while the cartridges are being aligned; once the power light turns solid, the printer is ready for use.
Do rate, if found helpful
Nov 27, 2010 | Lexmark X2600 InkJet Printer
How to change ink on an epson stylus NX105 printer
Here is how you can change the cartridge for the Epson NX105.
1. Turn on your printer with the its support stand on the right.
2. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended. Then press the stop button again to move the cartridge back to the right side.
3. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it.
4. Now, before opening the new cartridge package, shake it four or five times to redistribute the ink evenly. Then remove from package and be careful not to touch the green chip on the cartridge.
5.
Remove only the yellow tape or sticker on the cartridge.
6. Insert the new cartridge into the holder and push it down until it clicks into place.
7. Finally, , lift the scanner slightly, release its support, and lower the scanner.
That's it!
If you need illustration, please click HERE.
Please let me know if this helps you. Thank you for using FixYa.
Nov 22, 2010 | Epson Stylus NX105 All-In-One Printer
How do i eject the ink carrier?
hi there,
  1. Look at the Epson printer's LCD screen to see the ink levels for each cartridge. If your cartridge is completely empty, simply press the "Color" button. If your cartridge has a low ink level, press "Setup". Hold down the button on the upper left side of your LCD screen until the words "Replace Ink" appears, then press the "Color" button.
  2. Wait until you see the words "Open the scanner" on the LCD screen. Then lift open the printer top by pulling up on the side grips next to the scanner unit. Make sure that the scanner lid remains closed. The ink cartridge holder should move to the far right of the printer.
  3. After the cartridges have completely stopped moving, pull the cover of the ink cartridge holder up and toward you. Press in the tab of the cartridge you need to replace. Lift the cartridge straight up to pull it out of the holder.
  4. Unwrap the replacement cartridge and insert it securely into the holder. Press straight down until the cartridge snaps into place.
  5. Close the cartridge holder cover and make sure it clicks into place. Close the scanner unit and wait while the printer charges the new replacement cartridge. Wait until the word "Charging" disappears from the LCD screen before using your printer.
Do not turn off your Epson printer while the "Charging" message is still on the LCD screen because this may cause your inks to not fully charge. Turn off your printer only if there has been no response for over five minutes.
Clean up any ink spills with soap and warm water.
Replacement ink cartridge: Black (T048120); Cyan (T048220); Magenta (T048320); Yellow (T048420); Light Cyan (T048520); or Light Magenta (T048620)
Hope this initial info/idea helps.
Let me know for further instructions.
Thanks
Apr 29, 2009 | Epson Stylus RX500 All-In-One InkJet...
My epson d88 printer has 2 flashing lights, the ink charge and paper feed lights. this is preventing me printing out. this happened after i tried to change my inks. can anybody help?
I just had the same problem. Try opening the top flap on the printer and see if you can click the lid down on the ink cartridge box more firmly (until it clicks) - i had to force the cartridges to the left slightly to do this, although I'm not sure if thats neccessary. Then i pushed the cartidge box back to the right where it was before. The 2 red lights still flashed for me, but when i turned the printer off and on again it worked just fine. I hope this helps.
Jan 23, 2009 | Epson Stylus D88 InkJet Photo Printer
Removing black ink cartridge
Turn unit off first and unplug it from power supply, then replug and turn it back on.
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from its package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus CX6600 begins charging the ink delivery system.
Pls dont 4get to rate solution. Thanks!!
Apr 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Computers & Internet
Canon PIXMA MP150 All-In-One InkJet Printer Logo
49 people viewed this question
Clive
Clive
old marine
old marine
