Question about Cuisinart BFP-703 SmartPower Duet Food Processor
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
I have a Cuisinart BFP-703 blender/food processor duo. Everything has been working great for several years, but now the grating/slicing disc doesn't spin when it is attached. All the other functions work just fine. I can't figure out if some tiny piece broke off that is necessary for spinning the grater or if it is just starting to poop out. Thanks in advance for any help on this one. Cuisinart was no help when I called.
  • 8,596 Answers
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Posted on Mar 17, 2009
Lights come on, motor turns briefly, then stops
Check that blade can turn easily with unit unplugged. Fix that first then replace the fuse.
Dec 15, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
Cuisinart smartpower duet BFP703 food processor repair manual
Oh some of these answers... the most common issue with blender is that the removable blade unit starts to jam. So :
1. unscrew it, clean it and make sure it turns easy
2. open the unit and replace the fuse that blew up because turning the blade became too hard.
Voila
Nov 25, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
My mini cuisinart stopped working
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals (p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Instructions for the food processor of my Cuisinart Duet
Here is the link to the user manual with visuals 9p.6 is most helpful):
-Tha Mp3 Doctor
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Mar 12, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Lights are on but it wont run
If you have had your blender/food processor for less than 3 years, call Cuisinart and get it repaired in-warranty. You can find a new BFP-703 from $80-$100, and even an in-warranty repair will cost you $20-$30 in shipping (just food for thought). If you are Out Of Warranty, let me know, and I can give you some diagnostic assistance - if the shaft is just locked up, and can be oiled, that is a pretty easy fix. Anything else wrong with the unit is going to be tricky, since original internal parts are not available for sale.
-Tha Mp3 Doctor
Apr 23, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Food processor died
The plastic "clutch" with the teeth is probably cracked or stripped. you can buy a replacement.
Jul 13, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Blender Dead as a Doornail
open unit wil find thermal fuse replace.alternative the lid that covers bowl normally turns cliickinto position .this activates aswitch check if properly locked in
Mar 21, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Cuisinart BFP-703 SmartPower Duet Food Processor Logo
890 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
