Question about Toshiba Satellite A85-S107 Notebook
Cursor frozen aI was in "touch pad untility. and system froze up. Had to unplug to power off. Plug in and re boot ok but, cursor is still frozen...will not move.
How do I unlock my cursor on my laptop when the yellow light on the mouse pad is not on?
Do you have a micro USB device plugged in. Some touch pads automatically disable if you plug in any type of USB mouse device. You can also go into the device manager and uninstall the pad (do not use the delete/remove drivers option), then reboot. Windows will reinstall the device, and sometimes that fixes issues. Or do like it do and use a wireless mouse. I hate those touch pads anyway. ;-)
Jul 25, 2014 | HEWLETT-PACKARD HP ProBook 4525s Notebook...
The cursor on my laptop froze and now can only be activated using an external mouse
It sound like the touchpad has been disabled, either in the windows control panel or in the bios.
BIOS can be accessed during boot.
Windows control panel is accessed when running.
Apr 07, 2014 | Packard Bell Computers & Internet
Frozen cursor
Hit reset or hold the power button down until it turns off, turn it back on and if the cursor is still frozen you may have a problem with you touch pad.
Jan 05, 2013 | Computers & Internet
MOUSE PAD NOT TURNED ON
Re-Boot doesn't help? Unplug, remove battery, plug in AC re-boot.If that does not work boot in safe mode. If that does not work let me know
Oct 29, 2012 | Samsung N Computers & Internet
Comaq presario cq 71 cursor is frozen. PC shop man siad it was poor battery. Booted up from mains and cursor worked fine until recently. Mistakenly left battery in and powered down to hibernate. Now cursor...
yeah ..you have to disable the power saving mode..This is the only thing related with the battery usage that may disable the cursor..o r..just reinstall the touch pad..
to do that download its driver and run it into computer ..
here is the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3795238&
just select eh operation system and download the touch pad driver..
or go to control panel ..open the touch pad icon ..and in there select default settings ..or enable the cursor again ..if it is disabled..
if this is not working ..try reinstall it like I said ..It always starts a clean installation from the factory settings ..
Avoid hibernate it ..cause will always preserve the last settings ..just close it proper each time ..this way it will boot and recognize devices each time from the start ..
Dec 06, 2010 | Compaq Presario CQ50-215NR Notebook
My computer froze. It will open into Windows 7, but the cursor stays frozen
first scan ur windows with antivirus and then run reginout registry repair, then go to manage disk and check there mouse and touch pad option
Oct 05, 2010 | Acer Aspire One Netbook 8.9" Notebook
FROZEN CURSOR
Sounds like the touch pad is not working anymore. try using a USB mouse and see if that works. also, see if you can reinstall the touch pad software to fix that.
Aug 28, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Mousepad Frozen
the acer has a driver and software restore program on your desktop, I suggest you re install the driver for the mouse pad, you may have to use an external usb mouse to do it. try that
Jun 21, 2009 | ASUS Eee PC 1000H Laptop
Cursor frozen and cannot cut the computer off or move the cursor
Ok try to boot in native DOS if the unit still froze. If it froze then check your memory card, reseat or clean it with soft eraser only its edge connector. Do this when battery is disconnected and no any other power source is connected to the unit.
Then if it run native DOS. If you can backup your important files, installation code. This will end restoring your unit to restore factory, do you have your restore disc?
Or you can try first to run in safe mode/repair options. Check if it can do some system restore.
May 15, 2009 | Compaq Presario 1200XL104 Notebook
Toshiba Satellite A85-S107 Notebook Logo
248 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
