Question about Car Audio & Video
Jensen UV8 indash head unit . on my unit i have a "loud" icon but have no clue how to activate it need help please
  • 74 Answers
Sometimes you need to hold a button down to get into a sub menu
Posted on Feb 17, 2009
Just bought jensen uv8 touch screen and installed speaker wires will produce no sound except for sub input on rca please help?
it could be a case while you or someone installing the unit could or might have blown out the speaker output of the unit
try taking the unit out connect the red(acc wire) yellow(constant wire) together connect the black(ground wire)
get a test speaker and see if u get sounds
Jan 26, 2010 | Jensen VM9510 Car DVD Player
Hooking up backup camera to jensen uv8
That wire needs to run back and be hooked to the revese bulb. When the car is in reverse, activating the reverse lights the unit will get a signal knowing that you can use the camera
Mar 26, 2009 | Audiovox UV8 Car DVD Player
Jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Jan 28, 2009 | Jensen VM9510 Car DVD Player
Parking brake (pink wire)
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 13, 2008 | Car Audio & Video
J-link hook up
My Jensen TV/DVD unit came with a media box as well as the head unit. The media box was the interface where my iPod and XM antenna plug in, and everything is routed via a DIN cable from the media box to the head unit. I'd think you're missing that extra module that allows all the auxiliary hookups.
Jul 21, 2008 | Jensen VM9510 Car DVD Player
Jensen vm9412
the loud switch is normaly only for use with the radio module of the stereo does it work with the radio?
Jul 07, 2008 | Jensen VM9510 Car DVD Player
Loud Function
customer support suggested this: Turn the volume control, and while the yellow speaker icon is still visible, press and hold the volume control until you here a double beep. This confirms the new volume setting.
Jan 03, 2008 | Car Audio & Video
How to activate the "LOUD" in my Jensen UV8
Dec 08, 2007 | Jensen VM9510 Car DVD Player
Jensen UV8
get a Y_ adapter cable
Nov 26, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
