Question about iLO 3200 32 in. LCD Television
Screen is blue says composite, no signal.
Wont respond to any button comands except power button
  • Anonymous Feb 10, 2009
    tv is stuck on componet channel.
TRY AND FIND VIDEO BUTTON ON TV REMOTE AND PRESS VIDEO BUTTON. ON THE MENU USE UP OR DOWN ARROW ON REMOTE TO CHANGE FROM COMPOSITE TO ANALOG TV.
Posted on Feb 05, 2009
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
My ps3 wont show on my tv its a hd connection, all ive got is a blue screen. ive tried holding the power button down til u hear the beeps but still a blue screen. hope u can help
Try using the composite (yellow, red, white) cables that came with your PS3 to verify if it is an A/V error with your Console.
Since you held the power buttons till you heard the beeps, you reset the console to the factory standard which is a composite signal. Wh
If you see a picture, then it is not the console it was the hd cables you were using. If not, then you will have to send in your PS3.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
How to remove "no composite inpute signal"
If you have the same problem with both monitors, it sounds like a display card setting or problem.
The chances of you having the same problem with different units is 1- 50.
Try the monitors on a different PC and get back to me.
Sep 02, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
No signal
Replace the button board
The volume down switch is shorted
Still having problems
Email me @ rudygoberdhan@hotmail.com
May 26, 2009 | Akai LCT2785TA 27 in. LCD Television
Blue screen on my haier 37 inch tv
my tv just went to a blue screen one day. I can turn it on and then it will just remain on the blue screen. Any button (except the volume) I push on the remote comes up on the screen "no signal". What would you suggest? I have been reading about replacing a fuse or board? Most of those are on the 42 inch version---I have teh 37 inch version.
Feb 02, 2009 | Haier HL37S 37 in. LCD HDTV
Olevia T.V problen
Try selecting a different input, or checking the device which you are receiving the signal from. A blue screen typically indicates that there is no signal.
Mar 16, 2008 | Olevia LT37HVS 37 in. LCD HDTV
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Nothing!
I do not have a solution but the same thing happened to me today. Just nothing
Jun 01, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
131 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
