Question about Minolta Dimage Scan Dual II Film Scanner
Dual II error messages
I recently sold someone my dual II scanner that worked perfectly up to the point that I boxed it up and shipped it off, now he say's it does not work and every time he loads the tray up it kicks out the tray and says error 44 or error 61 and goes into setup mode. I have no idea what he is talking about all I know is that it worked perfectly b4 shipping.He say's he has downloaded the latest drives all with the same result.
  • bill_weaver Sep 15, 2008
    ( Alomost ) completely dead Scan Dual III,. pilot light comes on, some motor noise, then nothing. Computer does not detect scanner. All pcbs look ok, no ribbon cables loose. I have been quoted twice the units' value for a " professional " repair ( in Germany!! ) - any ideas, anyone ??
I have the same problem. I opened the scan to see why it says error 44 or error 61 and goes into setup mode. There is a lead wire (Flat) connect to the front control PCB out of the socket. Insert it and OK! Believe me.That's the problem. That is the problem of Minolta. The vary of Temp. may cause it out of the socket.
sean from China.
2008.04.04
LLXXFF999@163.com
Posted on Apr 04, 2008
    Genius:
  • 2,985 Answers
What operating system is he using what operating system was it operating under for you?
Posted on Aug 02, 2007
I am looking for a driver for the dimage scan dual ii that will work with windows 7
The drivers that came with the unit will work fine under Windows 7. If you get warning messages while installing them, just choose to ignore and continue.
Feb 06, 2011 | Minolta Dimage Scan Dual II Film Scanner
I'm missing the slide tray for my Dimage Scan Dual IIl Would like to find one to buy.
I have the slide tray to a Dimage Scan Dual II and am looking for negative tray.
I would be perfectly willing to swap it with you or buy it off you...
Jan 23, 2011 | Minolta Dimage Scan Dual II Film Scanner
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Aug 07, 2009 | Syscan DocketPORT 465 Scanner
I just installed a (new out of the box) HP LaserJet 3380 All-In-One printer/fax/scanner. I have NOT set up the fax function (no telephone line available). The unit is connected to my computer with a USB...
WHen you open the scan application and get to the point just before you scan... open at the top menu "File" and request to "Save As" and give it the "Name.BMP" see if that helps..
You named the folder but you did not mention naming the file you want to save????
Aug 04, 2009 | Office Equipment & Supplies
I have a Minolta Dimage Scan Dual II which has a power-on-reset problem. It only starts up properly when it has been switched off for a couple of days. Does anyone have a circuit diagram so that I can...
I probably have ran into this issue as well if I leave the scanner turned on, my Diamge Scan Dual II gives me an Error= 5 on Win2k or Error=1 on XP
Last night I opened the scanner up found a loose ribbon cable and managed to the scanner working however it was left on over night and Puked out with error codes again
Jun 07, 2009 | Minolta Dimage Scan Dual II Film Scanner
Minolta Dimage Scan Elite 5400 - Vista driver?
1) Install all of the usual Minolta software in Vista if you haven't already.
2) Create a new folder somewhere
3) Create a new txt file in that folder and name it minolta.inf and paste this into it:
; minolta.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. Once installed, all the normal Minolta programs now work just fine. Enjoy!
I tested this on Vista 32 Ultimate with a Dimage IV but it should work on all the models listed in the .inf file.
Aug 02, 2008 | Minolta Dimage Scan Elite 5400 Film...
Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
3) Create a new txt file named minolta.inf and paste this into it:
; scanners.inf -- Test Vista Minolta Film Drivers
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. All the normal Minolta programs now work just fine. Enjoy!
Jan 27, 2008 | Konica Minolta Dimage Scan Dual IV Film...
MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
Dec 25, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Minolta Dimage Scan Dual II Film Scanner Logo
193 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Inky Fingers
Inky Fingers
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
