Question about LG KC550 Triband GSM 5MP Camera MP3 Phone Black
Memory card slot
I cannot access my memory card, i try to format the card but it say (this card is not available) or (bad format error) can someone help
  • dash123 Mar 16, 2009
    Trying to format memory card and get memory card not available coming up on the screen
  • themuel Mar 25, 2009
    i have the same problem m8, if you finally know how this problem is solved plz let me know very much appreciate it thanx(Y)
    Genius:
  • 1,234 Answers
Hello Mr.
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    What formatting is necessary to play videos on the SD card slot of my Magnavox NB500MG1F Blu Ray Player?
    The SD card is mainly for photos, but you can do video.
    The SD card needs to be formatted as fat 16
    The video has to be profile 1.1
    If you use the larger SDHC cards, they can be formatted fat 32.
    It works best if you format it with the player and not your computer.
    May 17, 2014 | Magnavox NB500MG1F Player
    Magnavox NB500MG1F Blu Ray Player: I've been having trouble getting the SD card slot to read the videos I put onto the SD card. I've tried everything from converting all the video files to AVCHD file types...
    It is obvious to me that the player can't read the video off an SD drive. In my experience that card slot is for installing updated firmware not video material.
    Mar 23, 2017 | Audio Players & Recorders
    Memory card error
    When you tried to format, did it complete formatting? If format failed then the memory is bad. Buy a replacement. Format should be completed in the camcorder for it work right.
    If format completed, and you can write to and read from the memory card on the PC, then there may be a problem with the camcorder card reader. Try blowing out the card slot with canned compressed air. (Don't use a tire inflator) And gently wipe off the contacts on the card with a QTip dipped in alcohol. Good luck.
    May 12, 2013 | Samsung SC-D103 Mini DV Digital Camcorder
    After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
    It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
    You can find Micro SD cards here for purchase.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=micro%20sd&IsRelated=1&cm_sp=KeywordRelated-_-micro_sd_card-_-micro%20sd
    Sep 22, 2011 | SanDisk 2GB microSD Memory Card
    When I put a card inside my camera D200, the massage displays and blinking "For", whats the issue and how can i fix it
    Sounds like a format error. Try formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
    Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for the camera was written.
    SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
    Nov 10, 2010 | Nikon D200 Body Only Digital Camera
    Memory card reader
    Try format the card using FAT (not FAT32 or NTFS).
    May 29, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
    Memory card slot
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    May 27, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
    External memory card for LG kc550 won't work
    I was also getting bad format error on my LG kc550. Did a little research (read the instruction book) and if you want to properly format your card to work with the phone you must insert the card into the phone then connect the phone to your computer via the USB cable supplied. Go to "My Computer" and you should see that the phone and memory card are displayed as two separate external devices, when you try to access the memory card your computer should ask you to format it. Click Ok and a Format box will come up, click Ok again and your computer will format the memory card acordingly.
    Unfortunatly this resulted in my losing 4gb of space on the card, i dont know wether its based on percentage or a fixed amount the phone needs but if thats the case you will need more than 4GB for your card to be formated for your phone
    Mar 31, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
    Sony erricsson mobile memory card not reading
    change cable if u use samcable for both cardreder and phone.
    Mar 30, 2008 | Intel Motherboard
    LG KC550 Triband GSM 5MP Camera MP3 Phone Black Logo
    52 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
