Question about Motorola Mobility RAZR V3c Cellular Phone
My Razr V3 got wet...
I had random problems with my razr even befor it got dropped in the pool- it would ring but the screen would be normal, it was as if it was just ringing for the heck of it, but then 5 min later it would say one missed call. Or i would turn it on and go to my contacts and all my contacts would be the same person listed over and over, same with call history. then it was dropped in the pool- i fished it out not 2 seconds later- but it was enough that when i tried to turn it back on all that would happen is the backlight on the keypad would light up. no noise, nothing and the dot- which if i recall corectly was red when i bought it- is now very red and the dye comes off on your fingers. it is drying out now but it has been about 5 hours, and i took the battery out- what else can i do? i didnt insure it!
  • strangla May 01, 2008
    i didnt even know my phone got wet i sat it on a little table next to the toilet and the shower. water got on the table and leaked under the phone. when i was out of the shower it was working then all of a sudden it died. i tried to turn it back on and it would go then shut off again. then after like twice it wouldnt turn back on and the keypad was plashing on and off in a real weird way. i toke the battery out for a minute or so trying to fling and **** out the moisture. i stuck it on the charger over night hoping it would get enough juice but this morning it still didnt work. i stuck it on the top heat vent in my truck for about 15 minutes but still no go. the battery is not in it at this time WHAT ELSE CAN I DO???
Pool water contains chorine..which is harmful
dip it into distilled water and then dry it totally.keep it in the sunlight for 3-4 hours..it's gonna work
Posted on Apr 07, 2008
I just used a blow dryer when it happened to mine, and i works good, but the 6 and 9 kys are hard to press and it says invalid battery
Posted on Aug 12, 2007
I read that you can put it in a clear plastic bag with some silica packets to help dry it out!
Posted on Aug 05, 2007
  • 28 Answers
Pool water is extremely corrosive due to the chlorine.............tough one.
Posted on Aug 01, 2007
SOURCE:
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
When these phones get wet, there is perminent damage. The fix is to swap out the circuit boards that become damaged. It is cheaper to buy a new phone rather than fix it.
Jerry G.
Jun 28, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Problem with a RAZR V3
sounds like youve just had a short in your screen wiring. go back to where you got the phone and ask for an exchange
May 01, 2008 | Motorola Mobility RAZR V3
you need to take the phone to a mobile service center and ahve them fully service the mobile and replace what parts are needed to be replaced.
Apr 14, 2008 | Motorola Mobility RAZR V3
V3 ring time
contact your carrier they can adjust the number of rings in the network. I think there is a 30 second max though about 6 rings
Jan 02, 2008 | Motorola Mobility RAZR V3
V3 RAZR constantly pressing right?
As you describe it, your problem is the keypad. Maybe dirty or wet inside though that part is a totally replaceable pad with a connector only so you must buy a replacement and replace the broken one.
About how to do that: being the razr a common phone is pretty sure you'll find guides, photos and maybe videos around the web, googling, guiding you on how to do it. Maybe the shop where you buy the replacement can have a forum or guides.
The other option is to pay a technician to do it.
Good Luck...
Oct 20, 2007 | Motorola Mobility RAZR V3
Key pad is frozen
is your phone been dropped or wet? check local service center near our place.
Sep 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Phone won't turn on/charge
Kikimenor: Advise. If this is your 3rd RAZR V3, you must encourage Cingular (Now is the new AT&T) to replace your whole unit with another model. A friend of mine exchange his phone 4 times, until Cingular replace it. Motorola had too many problems with RAZR phones and that's why they launch quickly the SLVR L7. They still producing the RAZR, because users love the style and shape of the phone, but reality is that Motorola had several heavy issues with RAZR (Bluetooth, batt, microphone, etc.) If you're paying for an insurance on your unit, encourage them to replace it. SithPitt
Jul 04, 2007 | Motorola Mobility RAZR V3
V3 razr goes to white screen
software problem u must contact service center and do flash it
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
273 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
