Question about Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
I have two Magellan Roadmate 700's. One is V5 and the other is v3. My Version 5 has some audio problems that is why I purchased the second one. Is there anyway I can copy the harddrive from the V5 onto my computer and then copy the files into the Version 3? Thanks Patricia
  • al fong Feb 24, 2008
    have 3 magellan 700 one has newer maps the other old can i use the one good maps to upgrade old ones?
  • 4 Answers
This is not exactly what youare looking for but it will worth to know i guess. My 700 has auido problem. when i turn it on, i donto get any sound output. If you do the followign, configuration/diagnostic/audiotest, i recover the sound, till i touch sound volume bottom. It works fine considering nto everyday i need sound. I suggest you to
Posted on Jan 20, 2008
SOURCE:
Magellan roadmate 700
go to the magellan website and all your answers are there.
Sep 13, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Lost sound and audio
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.your choice
Jan 22, 2008 | Magellan RoadMate 700 GPS Receiver
Freezes at street name screen
Yes - bin the Magellan - I have a Roadmate 700 and just bought the updates but to get cameras loaded is a major hassle and Mag Support just do not respond... what a waste of money my Magellan has been, cost over £800!
Am now buying a Tomtom 720T with cameras preloaded - it does an auto update each time yu sit the unit in a cradle attached to your PC.
Jan 05, 2008 | Magellan RoadMate 700 GPS Receiver
Downloading new version 6 to my roadmate 700-760 gps
I had a very similar problem downloading the new version for my roadmate 700 as well. I chose to shut system down .I then unplugged everything. I reinstalled the dvd into my computer.I powered up the roadmate700 and hit the enter button and the screen came up to pick user I hit user one. I plugged the USB calble in and started the download again and it worked out for me just fine. I hope this works for you also. Good Luck
Dec 21, 2007 | Magellan RoadMate 700 GPS Receiver
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Oct 24, 2007 | Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
109 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
