We replaced our old wash machine with a front loading LG Steam Washer 2487. When the machine initially fills, it sucks water in short, sharp bursts, which is making our pipe bang loudly. Short of cutting open our walls to anchor our pipes down better, are there any other suggestions for addressing this?
  • 15,935 Answers
This is called water hammer - and is caused from AIR in your pipes.
There are Hammer Arrestors made to eliminate (or lessen) the hammering.
You should also bleed the air from the pipes - and re-prime them.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
Feb 17, 2013 | LG WM2455 Front Load Washer
Lg steam washer 2yo 3 yrs old . Refresh cycle produces bribble of water rather than steam and leaves clothes wet
The steamer unit may be overfilling. Check the water valve and see if it leaking. If it's ok, you will need to replace the steamer unit. Good luck
Jun 17, 2011 | LG F1402FDS6 Front Load Washer
LG Front loader humming, not filling with water, or operating
its not the filter problem.the motor is faulty and that needs replacement. you can get motor at  www.repairclinic.com to avoid circuit board damage do not try to on the machine again n again till the motor gets replaced as it can short circuit the main board too.
May 06, 2009 | LG WM2487H Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water Surge Making Pipes Knock
What you are describing is called "water hammering" and is caused when a water valve shuts off quickly. The momentum of the water moving within the pipe causes the pipe to bang when it comes to a sudden stop. Plumbers can install an air chamber to absorb the water hammer (just like a shock absorber) but you might try ones that you can just screw onto the hoses behind the washer. I have seen them at places like Home Depot in the plumbing department. (hope you can find someone who actually knows what you are talking about to help you find them) Alternately, you may be able to find them at a hardware store or appliance parts supplier.
Feb 01, 2009 | Washing Machines
LG Steam Washer
please give me some more details like model number. that will be easy
Apr 10, 2008 | LG WM-2277HW Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
287 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
