Water Surge Making Pipes Knock
We recently replaced our old washer with an LG Steam Washer 2487. When this new washer fills with water, it sucks water in intermittently at first, causing the water pipes to knock very loudly. Aside from cutting our wall open and fastening the pipes down do you have any other suggestions?
  • Anonymous Apr 21, 2009
    Just replaced our Amana wahser and Dryer with LG front loaders. We love the machines, but the pipes start a number from the "Blue Men Group" on our pipes...
  • 1,543 Answers
What you are describing is called "water hammering" and is caused when a water valve shuts off quickly. The momentum of the water moving within the pipe causes the pipe to bang when it comes to a sudden stop. Plumbers can install an air chamber to absorb the water hammer (just like a shock absorber) but you might try ones that you can just screw onto the hoses behind the washer. I have seen them at places like Home Depot in the plumbing department. (hope you can find someone who actually knows what you are talking about to help you find them) Alternately, you may be able to find them at a hardware store or appliance parts supplier.
Posted on Feb 01, 2009
LG WN1832CW does not fill with water
The fill valve may be defective or there may be a controller malfunction that prevents the fill valve from operating.
Nov 22, 2013 | LG WM-1832C Front Load Washer
Lg steam washer 2yo 3 yrs old . Refresh cycle produces bribble of water rather than steam and leaves clothes wet
The steamer unit may be overfilling. Check the water valve and see if it leaking. If it's ok, you will need to replace the steamer unit. Good luck
Jun 17, 2011 | LG F1402FDS6 Front Load Washer
Our PAV2300 has a problem filling. When I set it
I can tell you its not in the hoses, typically in the washer where the hoses go in there will be a screen. Check these screens, you will get a lot of sediment built up on these, i have to clean up mine every 2 years. This will still have to be done even if there is a water softener. If this is not the problem then I suggest checking every valve in the cold water system. Making sure they are opening fully.
Jun 24, 2010 | Maytag PAV2300 Top Load Washer
When our new LG washer starts its cycle, the water seems to do quick bursts into the washer making the pipes make a bad noise. Any advice?
The quick burst of water is normal for the LG washing machines, its the way the water valves work. The noise you hear, sounds like the water lines jerking, and hitting against the wall, or the cabinet itself. You may need to get some tape, and tape the lines to the unit itself.
Mar 22, 2010 | LG Washing Machines
Pipes are banging
you can purchase a "hammer arrestor" from any major hardware store and have it installed which should cure your problem.
Feb 11, 2010 | LG WM2277H Front Load Washer
We replaced our old wash machine with a front loading LG Steam Washer 2487. When the machine initially fills, it sucks water in short, sharp bursts, which is making our pipe bang loudly. Short of cutting...
This is called water hammer - and is caused from AIR in your pipes.
There are Hammer Arrestors made to eliminate (or lessen) the hammering.
You should also bleed the air from the pipes - and re-prime them.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 01, 2009 | Washing Machines
Banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Sep 17, 2008 | LG Washing Machines
LG Steam Washer
please give me some more details like model number. that will be easy
Apr 10, 2008 | LG WM-2277HW Front Load Washer
Steam iron just spits water
Hiya .. your problem is more than likely to be one of two things
1. The element is overheating, which means the thermostat is not functioning as it should.. can you hear the thermostat Clicking? if so
2. No matter how soft your water area is.. there is always scale build up around and within the jets, try a good propietary descaler..... White vinegar is a good alternative.
Fill the iron with equal parts vinegar to water, and letting it steam until dry, rinse the tank with clean water, refill it and shake the water through the steam holes over a piece of newspaper/material... Test an old cloth before ironing on anything expensive. It should sort your prob ..... never advisable do this on a new iron as the acidity may damage the iron!
Regards Faggly
Mar 23, 2008 | Washing Machines
LG Tromm Water filling
water hammer valve at home depot fixes problem for like 20 bucks
Mar 10, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
1,198 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
