Sharp split system, cutting out
The inside sytem fan is running but the compressor outside only kicks in for a second and then stops even though the room is not cool. The inside unit fan will run for a few minutes after that and them the timer light will flash up on the unit and it cuts out. I have cleaned the filter inside and the condensor outside so nothing is blocking its air flow. It ran fine for a few days in the extreme heat but now isnt happy.
  • monaroman Feb 01, 2009
    Thanks for your reply, it is cutting in for only a second before it cuts out again, does that mean it is low on refrigerant and i can just get it re-gassed?
    President:
  • 1,214 Answers
If this is running in A/C mode, then I bet you have a low refrigerant charge. The compressor is dropping out on low suction pressure if it's cutting in and out every 5-10 minutes or so. If it takes hours, then it's likely a different problem.
Reply back and I can help you (been in that business for over 30 years.).
Posted on Feb 01, 2009
  • Mark Egan Feb 01, 2009
    I am going to lean toward saying yes, get it regassed (so to speak). If you can find a wiring diagram, look to see if it has a low suction pressure switch. If it does, and it's cycling every 2-10 minutes, it's low on gas.
    Let me know if I can be of further help, and, if you don't mind, honor my help to you so far with a FixYa. This isn't one that I can fix for you using a computer, but chances are we've nailed the solution.
    Let me know what you find on the units, and I will be happy to help more if you need it.
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
4 ton Amana -heat comes on sporadic in spring and fall (Every season change) Heat worked through 20 degree weather. Thermostat at 74. Today is 100% humidity and 52 degrees outside and heat won't work. By...
Assuming this is a heat pump I'm guessing you have a bad temp sensor. Your outdoor fan is likely controlled by a temp sensor so it only runs as needed during heating. Fan not coming on and compressor still needs cooled therefore compressor protection kicking in?????
Aug 12, 2017 | Amana Heating & Cooling
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Jul 09, 2010 | Fedders C36ACD1VF Split System Air...
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Fan is still running in house constantly
Check your wall thermostat to make sure the "fan" switch is in the "auto" position. If it is set at the "on" position, the indoor fan WILL run continuously. Not really enough info as to what type of split system you have. Gas? Electric? Heat pump? Oil? Wood? Newspapers? See what I mean? Is it variable speed? Do you have a "special" thermostat for certain operations? Does your system incorperate inverter technology?
Apr 24, 2009 | Ruud Central System Air Conditioner
Have a near new panasonic cs-e28hkr split system air conditioner and the outside condensor fan continously runs even with inside unit is turned off? Thanks
Sir/madam,
If the inside unit (evaporator) is turned off absolutely.
The condensing unit must be turn off outside because the power
are derived comes from the evaporator.
Possible it seems on the cut out stage inside and remain the power still on
Otherwise theres somebody tamper the connection?
Fan cable consist of 3 wires
1 Common line
2 Start /stop line***Change the connection of this wire where it located, To On/ Off switch of the
evaporator inside unit
3 Ground green line/Earth
note: you can get all that wires inside the power supply in evaporator area.
If still under warranty inform the manufacturer
r_ic7
Nov 29, 2008 | Panasonic Heating & Cooling
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Heating & Cooling Logo
169 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
