Question about Panasonic KX-TG1033S Cordless Phone
Water driping out of split air co unit
Water drippind from air co
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
The drain hose could be clogged or the drain pan could be blocked. A service technician can correct this. Give an air con technician a call. This can be done by yourself if you know what you are doing but it is best to leave it up to the professionals
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
My samsung air condition driping water in the room
make sure unit is pitched back so water can flow out back of unit.
and check under unit outside for a clogged up drain hole.
Jul 16, 2010 | Samsung AW0693L Air Conditioner
Compressor starts, unit runs and we have no water driping from hose 12 mo. old.
How high is the humidity? If the air has less humidity that the humidistat is set for, you won't get any water.
May 13, 2010 | LG LHD65EBL Dehumidifier
Driping water inside house, blocked pipe? Mike
Take a wet/dry shop vac and find the drain line. Pull a vacuum on the drain line to dislodge any blockage. Worst case, blow into the pipe but cover everything inside because it will get wet!
Mar 13, 2010 | LG Art Cool LA121HNP Split System Air...
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Condensate drain not working. Water driping from entire attic unit. Have flushed and vaccumed line to no avail. Secondary tray does drain but water drips outside the tray area. American Srandard Allegiance...
the drain coming off the unit is the one you need to clear, not the secondary pan. its usually clogged in the P trap which is usaully not far downstream from the outlet on the coil.
Sep 13, 2009 | Heating & Cooling
The coil is driping condensate down on fan housing and running on the base plate runing down the wiring to the contacts the runs on floor
I'm assuming this is a split sysyem in a closet type location? Unplug the electricity and pull off the panels. It should quickly become apparent whether the piping has pulled loose or the drain is plugged. If the water is spilling uniformally across the unit it is probably plugged and can be fixed with some drain cleaner.
Jul 09, 2009 | Carrier Heating & Cooling
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Panasonic KX-TG1033S Cordless Phone Logo
35 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
