Question about GE Profile DPSR473EW Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
The timer doesn't work and the level of heat in the drum seems quite low. I assume the two issues are connected and fixing one will more than likely fix the other.
  • aclay Feb 10, 2009
    I apologize for not replying sooner. this is an electric unit and I replace the timer. It didn't fix the problem. The timer works in the "timed dry" portion of the timer but not in the two automatic portions. So...do you have any suggestions.
  • Maintunivers May 11, 2010
    Is this a gas dryer? If so...
    Do you see the ignitor come on? (Needs to be bright red, not yellowish)
    Do you hear a "click" noise about 20 - 30 seconds after pressing ON?
    Do you see an actual gas "flame"?
    Complaints of "insufficient heat" may be caused by the ignitor trying to work/coming on; but, no gas is entering the dryer combustion tube "igniting/combusting" (flame). This would be an indicator of a bad ignitor. However, insufficient heat can also mean you have a clogged vent-line as well.
    I am unsure and curious to know if the ignition problem may address the timer "appearing to not work". What makes you think the timer doesn't work? Not rotating? Ensure you have on the proper settings as well. I would address the insufficient heat first.
    -Maintuniverse
    Scholar:
  • 42 Answers
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Posted on Feb 11, 2009
Ge dryer Model # DPSR473EWOWW
once you get the dryer apart & remove the drum its very siimple
a 10 minute job if that
Apr 21, 2014 | GE Profile DPSR473EW Dryer
Ge dryer Model # DPSR473EWOWW coil proper installation
once you get the dryer apart & remove the drum its very simple
a 10 minute job if that & if your not sure get a service tech so you dont do more damage
Dryer drum turns, heats, but then heat shuts off before timer has finished.
The heat is supposed to turn off ten to fifteen minutes before the end of the cycle. It's a cool down period.
Jan 08, 2014 | GE Profile DPSB613G Gas Dryer
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
Mod # DPSR473EWOWW There does not seem to be an actual bearing back here. But I do notice there seems to be a Teflon like sleeve that seems damaged and needs replacing. I would think that would take care...
that's it but when you order the part you get everything,if you look inside the drum you'll see three screws,you remove the screws and pull off the shaft and bracket assy. then you get the sleeve bearing and the rear retainer bearing and the strap arm and all new screws,part number WE25M40 and it's around 40 to 50 dollars..copy and paste http://www.youtube.com/watch?v=IOx-tLgq67Q
Jul 03, 2011 | GE Profile DPSR473EW Dryer
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE DPSR473EWOWW Electric dryer that has great ventilation pressure and heat is at 135-140 on cotton regular heat settng. The timer portion (20, 30, 40, minutes setting) works fine, but if you put...
Hey richn14, I have a dryer idnetical to yours and bought it from one of my friends, and the guy that owned it before them was/ is a total idiot ( i know him, unfortunatly) and have had to do quite a bit of wrok to my dryer.What im thinking it is, is a loose connection on the timer, ive dealt with that or the timer itself is bad/going bad. When I was working on my dryer I was amazed at all the electrical connections on the timer, and the connections on the motor, well, blew my mind. If you are going to check this out yourself and need to know how to take any part of the dryer apart let me know and ill post it on here or can email you, either one.
Nov 06, 2010 | GE Profile DPSR473EW Dryer
DPGT750GCPL heat issue
What do you mean by "215 or 20 seconds"?
May 11, 2017 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Sep 17, 2008 | GE Profile DPSR473EW Dryer
Dryers Logo
474 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
