Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Red light stays on after lamp replacement and reset
I have a 2004 wd62525 mitsu with very low hours. The red light came on so I replaced the lamp. Never got a picture even after hitting reset.
  • Anonymous Feb 02, 2009
    I have a Mits WD-52825 diamond series with same issue. Replaced bulb, reset multiple times and no picture. If you look closely at the screen you can see a faint glowing after tv is on for about 10 seconds then it goes out and after a bit the tv shuts down and the red light of doom fries your corneas.
  • Mitsubishi Master
  • 8,617 Answers
If the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Feb 01, 2009
Mitsubishi wd-60735 no picture and red lamp light stays on
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
I have Mitsubishi WD62525 for the past 5 years. Last week the lamp light came on RED and I replaced it with a newer lamp and the TV still doesn't work. The RED light continues to stay on. Any ideas on what...
check to make sure the lamp cover is pressing the lamp switch in it is at bottom right corner of lamp panel, also make sure lamp is set in properly,another thing to check is the lamp cooling fan panel on right back side,remove and clean filter and replace
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Changed lamp and now turns on and only stays on for about 5 minutes and red lamp light stays on in an acer ph110 projector
Hi, what you need to do is reset the lamp hours to get the red light to go if it is a new lamp. To do that plug in a source such as a laptop or dvd player. When the display from the laptop or picture comes up go into the menu and reset the lamp hours I had the same problem. Hope this works if not let me know.
Nov 10, 2010 | Acer PH110 Multimedia Projector
Have wd62525 mitsu status light flashes tv wont
The status light flashing usually indicates the lamp cover door or the side air vent door are open or the switchs are not working.
Mar 16, 2010 | Televison & Video
I have a 2005 52 inch Mitsu turn it on and it goes to red light
di you replace the power for the lamp in your manul it will show you the lite set for your tv it it will give you i ideal what wrong. i see so with bad power supply or
the balstor go bad to i chang lamp bastor frist. when
the lamp go bad it will show you it the lamp in front of dlp. i hope this help you out.
Dec 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsu WD62525 - replaced lamp & after startup, lamp light is solid red. Anything else I can do?
Try the V26 Power pwb repair kit at www.tvrepairworld.com that will usually repair the issue. The kit contains the parts and the CD with instructions
Nov 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD62525 does not turnon - Lamp light on constant
Its more likely that the Capacitors on the power pwb have failed You can get the V26 Power board repair kit at the following link which has instructions. That is the most probable fault on your model DLP when the lamp wont light. Heres the link its listed under their repair kit category.
Dec 21, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsu-wd-52527 lamp replacement
The lamp in this TV is very easy to change. I recommend to use your owners manual, but the front cover snaps off, using screw driver open lamp door, unscrew lamp, pull out with handle, make sure lamp is cool. Replace, follow onscreen display to reset lamp hours. Use remote to enter information.
Feb 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
267 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
