Question about Motorola Mobility RAZR V3i Cellular Phone
It wont turn on
It was fully charged then the next time i tried to turned it on only the key pad lighted up after 2 to 3 secs of pushing the power button, but it will only stay on for one second and then off. Besides the key pad illuminatitng for one second nothing else happen. Any ideas
  • 28 Answers
Sounds like water damage but try this......... 1) press the * and # and Power button all at once - if the screen fires up with a black screen and some info - then you can flash the phone and hopefully recover it; 2. If the above works - you need to find a flash file and the software to flash it with Good Luck
Posted on Aug 01, 2007
SOURCE:
Can't get it to start turn key on lights and dash gauges go from right to left but engine wont turn over battery fully charged?any ideA what might be wroung
look at relay and wire connections to starter if power to starter than starter solenoid or starter gone bad it no power check battery --key ,if worn ignition may not be reading key -if key has chip in it chip may have gone pad --ignition switch went bad
Jul 29, 2015 | Cars & Trucks
Tablet wont turn on
Most tablets can be reset by holding down the power key for a period of time 15 secs 30 secs etc. power on and then hold down the power key to see if it resets the device?
Dec 06, 2013 | Polaroid Tablets & eReaders
Have the phoenix s35015 scooter. The battery is charged, put it in the scooter and turn key. All power lights up to the green, lightsheadlight can come on and horn beeps when pushed. The red light does...
make sure you put it in "gear" completely sometime you can get it almost locked but its still in freewheel, flashing light is error code, do a count of blinks and stops, look in the back of book for trouble codes
Oct 01, 2017 | Drive Medical S35015 Phoenixcompact...
My compaq presario v3500 wont turn on again. i was using it, watching movie then it suddenly shutdown. my battery is fully charge and the charger was connected. so i try to turn it on and it wont start....
Remove the Battery and press power on for 1-2 minutes with out AC power .
Please turn on the laptop with only AC POWER (without battery ). Check it. it may turn on your laptop.
If display ok, then insert battery and use it...
Jun 18, 2011 | HP Compaq Presario 2200 Notebook
Tomtom sav nav 910 wont turn on even after pushing reset button with paper clip as recomended. It is fully charged. Any other suggestions
Hallo! Try this: press reset +poiwer on for 20 secs, release reset but keep pressing power 20 secs, it should power the light on, very fast to connect to computer in this time, because it stais on 10 secs, open it like a map, backup ALL data in a new map, format the device, connect to TomTom Home, make the upgrades, copy the maps Maps and Voices back to your GPS.
May 12, 2011 | Tomtom GPS
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
It turns on then off almost instantly, the batery is fully charged.
i hope it will gives you success.
Jan 18, 2011 | Kodak Cameras
When I turn my camera on, the screen is black and makes beeping sound? Also lens is stuck
Jan 17, 2011 | Cameras
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
Camera turns on then auto shuts down??
when the lens comes out grab it and lightly!!! push it to one side this worked on a cannon i have
Jan 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Motorola Mobility RAZR V3i Cellular Phone Logo
279 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
