Question about Yamaha RX-V663 Receiver
Want to add all of my video components to my rxv 663 reciever
I have installed all of my video components (tv, blueray, cable), now I want to hook them up to my Yamaha receiver. Can someone help?
    Scholar:
  • 93 Answers
The rx-v663 has 2 hdmi inputs, and 1 HDMI Outputs, The way I would run is 1 HDMI in dedicated to the Blu-ray, This will do the audio HD True digital, DTS-HD , then video out to the TV for HD 1080p resolution, On the cable box out do you have an HDMI 1.3? If so sport it to the other available receiver HDMI IN, net the same in/out as the blue ray, minus a 1080p result video which will only happen Blu-ray, cable will result 1080i HD and audio HD will vary with the signal broadcast format.
Posted on Feb 01, 2009
How to hookup all the units ,cable, vcr, dvd , tv.,and receiver
It all depends on what you have for inputs on TV really. Any video components should be hooked directly to TV via, best, HDMI, next, component. Component has great video but doesn't carry audio, for audio, you would have to use separate cable(s), digital optical being best. The best scenario would be to run cable/sat, dvr, etc, to TV then hook TV audio out, via digital optical, to reciever. You would use TV's menu to choose what you watch and, would have one audio out to reciever. Some, if not most recievers have video pass through but, it's not the best route and, you have more connections and more margin for error.
Jun 14, 2011 | Audio Players & Recorders
HOW TO HOOK UP HDTV CONVERTER TO PLAY VIDEO ON TV
Need more specifics. What TV do you have? If you just want to hook up the blueray, you can use an HDMI cable from DVD to TV, or red-blue-green component video cables, or red-white-yellow cables.
Feb 25, 2011 | Samsung BD-P1500 Blu-Ray Player
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Rxv-663 cant get surround to hook up to tv
connect your component to audio out from tv to your audio in at the back of your component
Jun 17, 2008 | Yamaha RX-V661 Receiver
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Yamaha RX-V663 Receiver Logo
225 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
