Question about Sharp EL-531VB Calculator
Nothing happens when I press a number??
My Sharp EL-531-WH display has a 'P' next to the '0'. I press a number and nothing shows on the display. Is there a lock button or something I have to press to unlock it??
  • Sharp Master
  • 7,993 Answers
There is no lock button. Calculator may be configured to be in computational mode you are not familiar with: It may be set to do base calculation on base 5, hence the p (pental). Press the reset button on the back, and the default configuraion will be restored.
You should give some time to learn the different mode of calculations.
Hope it helps.
Posted on Sep 20, 2009
I have a Sharp EL 315 WH
when you posh 3 numbers then 2nd F then it has the p it is not going to come off
Jun 01, 2009 | Sharp EL-531VB Calculator
How do I get factorial function on a Sharp EL 531 WH
The factorial function is shown on you calculator as n! To calculate factorial 4 you proceed as follows 4[2ndF][n!][=] this gives 24
Hope it helps.
Setting the time..
Normal 0 this is how ive changed the time before, note that you dont see the number you type in.
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Oct 27, 2008 | NorStar M7310 Corded Phone
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Decimal places too long on EL 531 W
change the mode to normal i.e. press the 2ndF key,MODE, 0
Sep 02, 2008 | Sharp EL-531VB Calculator
HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Aug 22, 2008 | Sharp EL-1750PIII Calculator
Exponential form
Hi - You can download the manual from the link underlined in blue below:
EL-531 W
You need to set it to "SCI" i.e. scientific mode to show the exponents:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 05, 2008 | Sharp EL-531VB Calculator
Alarm keeps beeping, reads 0
Try testing it first. Press the test/reset button. If it's operating properly on the display:
"GAS" - and it should beep 3 times. Then a number should appear on the display. It should be arround 200. Then it should beep 4 quick times, then nothing for 5 seconds, then 4 quick beeps that keep repeating. It will then show 3 numbers again for a few seconds. When they're gone it will be done resetting. It should show a flashing red light and a 0 or whatever the reading might be. Try this and let me know what happens. If this fixes the problem please rate as fixed. If not, please don't rate yet. Let me know what's going on and I'll be more than happy to help. Thanks.
Apr 15, 2008 | Kidde Nighthawk Combo Gas/co Detector
Sharp EL-531VB Calculator Logo
569 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
