Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Safely remove hardware not appearing in windows vista tray but the pen drive is appearing in my computer and im perfectly able to access the pen drive...i can see it under disks in device manager and in usb...i have tried it with three other usbs too...same error.even though for one wen i plug in the icon just appears and then disappears..i think i might have developed this after plugin in a corrupt pen drive but i dont know..can some help me..plz
  • 289 Answers
Ur computer might have scan your computer.
this will solve the problem.
thank u..
Posted on Feb 01, 2009
Cefc d33193
Often when this happens, the drive was removed without "Safely Remove Hardware" . Try different computers (Operating Systems) and when recognized, Use the "Safely Remove Hardware" key. Then try it on your laptop.
Oct 12, 2013 | Computers & Internet
16gb pendrive
Which operating system ?
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer.
This prevents data loss and extends the life of your external storage device.
Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive.
This is necessary for the device to be removed properly.
Don't forget to save your files before closing the files.
Right-click the "USB" icon marked with a checkmark.
It is located on the bottom right of your taskbar.
From the pop-up menu, click "Safely Remove Hardware."
A small window will be displayed.
Select the USB flash drive you want to unplug then click the "Stop" button.
A confirmation window will appear. Click the appropriate hardware device, then click "OK."
The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer.
Click "OK," then click "Close."
Click start all programs accessories windows explorer navigate to your usb drive right click on it select remove or exit.
Jul 27, 2013 | SanDisk Computers & Internet
My safe to remove icon has dissappeared how can re install it please
Which operating system ?????????
The system tray in Windows XP is the right side of the small blue bar at the bottom of the screen that houses the clock and a few other small icons. You can add icons to the system tray for ease of access, including the "Safely Remove Hardware" icon, which allows you to easily remove hardware from your computer.
Turn on the Windows XP computer and right-click the taskbar. Select "Properties" from the menu that appears. Check "Hide Inactive Icons", then select "Customize" A new window appears with all of the icons currently on the system tray, along with icons also for some programs that don't appear on the tray. Click next to the icon "Safely Remove Hardware," then check the box "Always Show". Click "Apply". Safely Remove Hardware Icon?
Mar 13, 2013 | Compaq Computers & Internet
I have a Transcend JF V30 -16 GB pen drive. I can add files to it once connected. However, if remove it and then reconnect it, files are not shown. The disc size is reduce as the data added previously. FAT...
Are you using the Safely Remove Hardware option? There should be a little icon in the tray that allows you to remove the drive safely. Alternatively, you can right click on the drive letter in My Computer and click Eject and/or Safely Remove to make sure Windows really does write your files to the disk. If that doesn't help, try reformatting the drive; if it still won't work, you probably have a defective drive, and you should try and return/replace your device.
Mar 01, 2011 | Electronics - Others
Normally you don't need a special driver for usual pen drives. Are you properly removing it via the Safely Remove Hardware icon in the system tray (in right corner, near the clock on the taskbar)? If you don't use the Safely remove Hardware command, then you pen drive can be damaged. Try it in other ports or check it for proper function by connecting it to another PC.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Sep 08, 2010 | Gigabyte GA-K8VM800M Motherboard
I purchase a kingston 32 GB pen drive but it nt work
1. Download this tool:
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 07, 2009 | Kingston Technologies 512MB DataTraveler I...
Detects but not actually.......
Are you hooking this device up to a windows computer or a linux computer?
Jan 29, 2009 | Microsoft Windows XP Professional
USB PenDrive
enter the pen drive into pendrive slot then go into cantrol pannel and click on add hardwer and the pen drive show on youer computer
Nov 17, 2008 | Microsoft Windows Xp Home Edition Sp2...
Pen drive not showing in my explorer.
Its a common problem with the pendrive, in windows. some time it doesnot detect or not showing clearly that device. you have to check your pendrive manufacturer and driver details. and also check it out driver signing.
Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the PEN Drive into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the PEN DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your PEN DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because PEN DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the PEN DRIVE assign one of them.
Jul 22, 2008 | Microsoft Windows XP Professional With...
Not able to open Kinston 2GB Pen Drive
on desktop, right click my computer, manage, Disk management. Do you see your drive there?
Mar 23, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
