Question about Toshiba 46HM95 46" HDTV
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Hi. I'd bought this TV in 2005 and the bulb blew after 6 months. I called in and had it replaced. Then it blew again in 6 months; but before this second bulb blew, the color was little bit off on the "orange" color areas. Other colors are fine. Now, i just replaced a new bulb myself, but the orange color problem isn't solved. I'd posted this problem in the forum but they said the problem was the light engine. If it's a light engine problem, will this light engine blow my new bulb if i don't replace a new light engine and continue watching TV? Thanks for helping...
  • Quyen Liu Aug 01, 2007
    The bulb is okay now, but the color is still off. Guess i will have to replace a new light engine. Any recommendations where i could get this light engine for a right price? thanks.
    Scholar:
  • 150 Answers
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Posted on Aug 01, 2007
  • les lake Aug 01, 2007
    P.S. the color sounds like bad color wheel in Light engine, or the DMD board.
Changed 6 lamps y65 none work can they all be bad
Sounds like the circuit that is responsible for sparking and maintaining the voltage to the lamp has gone bad. It's called the Lamp Driver.
Don't waste any more money on lamps. Get a tech to have a look at either repairing or replacing the lamp driver.
Sep 13, 2014 | Toshiba Televison & Video
62HM 95 TOSHIBA. HAD THE PICTURE JUST GO BLACK THE OTHER NIGHT. I HAD A LAMP FOR IT GIVEN TO ME BY A BUDDY IT MAY BE A USED ONE NOT SURE. REPLACED BULB TV CAME BACK ON BUT PICTURE IS TO DIM TO WATCH. DONT...
These Toshiba DLP's were lemons.
There was a class action lawsuit in the US and Toshiba were forced to issue a recall on the lamps. Toshiba replaced the first lamp for free but when the lamps are burning out every 6 months at a replacement cost of $200 these tv's are expensive to run.
Sounds to me like the light engine has failed. This will probably be a $800-$1000 repair.
Scrap it and take the hit.
Nov 01, 2010 | Toshiba 62HM95 62" DLP HDTV
Samsung HL-T5076S Tv blows bulbs about once a month
You're definitely not having a lamp problem. It can be your ballast not providing your lamp with the correct amount of voltage. Lamps should last a minimum of 1 to 3 yrs. specially if you bought a Philips lamp.
Look into your ballast. Samsung has a history with this ballast.
Mar 30, 2010 | Samsung DLP HL-P5663W 56" TV
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
I have a toshiba DLP it uses TB25 Lamp mine blew and i have a friend that has a D95 lamp, can I just take his bulb out and put it in my tb25 casing? they look the same
i would say get the right bulb for your right tv.... because if the other lamp that you want to put in yours from the other tv might have a higher amp and ruin your tv....so your better off jus getting a newer bulb that is supposed to go with your tv.
Jan 30, 2009 | Televison & Video
Lamps burned every 6-9 months.
This is indeed a very common problem with the Toshiba products. The reason I asked about the time is that the television bulbs are estimated to last on average 4,000 viewed hours, which you are only coming up short of 50%.
Toshiba is offering an extended warranty free on the product that does cover the bulb replacement.
http://www.tacp.toshiba.com/tacpassets-images/notices/dlplamp.asp
is the link for this extended warranty.
After researching your particular make and model, I have found that the average span for a bulb is indeed 9-12 months. Beyond this extended warrant, Toshiba is offering no further assistance, and will only replace it once. They have also been having issues with the color wheel going out at an average cost of $750.00 which under warranty they will replace one time only.
There is nothing you can do beyond replacing the lamps, however my suggestion would be to replace the television itself, and stay away from Toshiba.
Jan 19, 2009 | Toshiba 46HM95 46" HDTV
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
14 MONTH OLD TOSHIBA TURNS OFF BY ITSELF
I repair a lot of these and a average tv lasts like 3 years . It is not like the old days. I suspect the lamp or fans or therm protector.
I would call a local tv shop see what they charge for estimate it might be worth his estimate to find out what it is.
Thanks doctor video
May 27, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 46HM95 46" HDTV Logo
439 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
