Question about HP LaserJet 5m Printer
Printer "memory" problem; can print one page or less.
I have an HP LaserJet 5M. Gradually the memory seemed to get worse, because it would print one page, or the first few test lines of one page, and then print its page saying "This job requires more memory than is available in this printer." It then says several things to try, but the first two I can't find in the Owner's Manual.
They are "For the output format, choose Optimize for Portability.
"In the Device Settings page, make sure the Available PostScript Memory is accurate."
I did find how to Clear Memory and Reset Memory to factory defaults, but that didn't help.
On the Self Test/Configuration page I noticed I have small memory values compared to values in the Manual's example page. My I/O Buffering memory is 60 time less than on the sample page, and Resource Saving is not enabled at all because an additional 2 Mbytes are needed.
I did not try to reset I/O Buffering on the Menu. And I will get another toner cartridge, although that doesn't seem to be the problem.
I'm a 66 year old guy with little computer expertise. Should I take this
printer to a repair shop? I have a directory of good ones, but not my own car to carry it.
    Genius:
  • 2,120 Answers
Http://www.edgetechcorp.com/memory/upgrade.asp?cid=20135
It is very easy to upgrade the memory. I f you can't figure out how to do it, repost.
Posted on Feb 01, 2009
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Colors are all out of alignment on my HP LaserJet 3600
    the Maybe the problem with laser mirrors , because of dust
    it needs to clean it . hope help you
    Mohamed Hejazi
    Afaqnama Tripoli -Libya
    ipg@hplibya.com
    Mar 20, 2013 | HP LaserJet 3600dn Printer
    HP Laserjet 5m, appear error code 50...please help.
    Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
    May 20, 2009 | HP LaserJet 4m plus Printer
    Hp laserjet 2420 printer printing completely black pages
    remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
    Apr 04, 2009 | HP LaserJet 2420 Printer
    Attention light, print stops.
    either you upgreat memory or print order less than 50 pages at a time.
    Mar 14, 2009 | HP LaserJet 1320n Printer
    Hp laserjet p1006 printing jobs gets struck in printing queue
    I know this problems in my part it was the hp driver.
    My Solution is to use an compatible driver.
    HP Laserjet 5 / or 6 standard windows driver.
    After that i have not this problems.
    The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
    Dec 25, 2008 | HP LASERJET P1006 Printer
    Not able to take print on both side in hp 9000 normal series
    You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
    Read below:
    Shown at left:
    HP LaserJet 9000 series, base unit—
    LaserJet 9000
    base unit =
    • 50 ppm print speed
    • first page out in less than 8 seconds
    • built-in RIP-once technology
    • 300,000 pages-per-month duty cycle
    • 64 MB memory
    • EIO expansion slots
    LaserJet 9000n = base unit +
    HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
    • 100-sheet multipurpose tray
    LaserJet 9000dn = base unit +
    LaserJet 9000hns = base unit +
    HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
    • 2000-sheet input tray
    • 3000-sheet stapler/stacker
    Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
    Printer Pauses every few pages, seems to print slower than it shouls
    More likely to be Network print spooler issue, check settings on driver.
    Nov 09, 2007 | HP LaserJet 4100n Printer
    HP LaserJet 5m Printer Logo
    700 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
