Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer purchased in 2004, beeps and displays F9 code during whitest white cycle or heavyduty cycle when washing towels, this provokes unusual delays, frustration and ineff
As stated above, we have a whirlpool washer/dryer set (duet large capacity electric washer with matching gaz dryer. Ever since the machines were purchased, we have encountered a recurring problem with the washer. When washing cotton towels in the Whitest White or Heavy duty cycle, the cycle often stops with a beeping noise and the display of the F9 code, which incindentally is NOT defined in the owner's manual and the the pause/cancel button must be pressed twice and the cycle continued. This can occur 2 to 3 times during a single cycle provoking lost time, long cycles, frustration etc. Please help as the service repairmen have been less than clear as to what the problem is and we are close to losing confidence in the Whirlpool product that was so highly recommonded. Initially, the problem was caused as we understood due to the use of the wrong liquid detergent (NOT an HE product) We have since changed and still no resolution. Regards TNK
  • 1 more comment
  • reneeb Dec 18, 2007
    where is the drain pump filter located? i can't find it. i am a woman! i need help. no $ to pay for repairs, need to do it myself. am perfectly capable, but i received no instruction manual from my builder when he installed it into my addition.
  • Anonymous Jul 29, 2008
    Same problem every time I wash a load
  • Anonymous Mar 01, 2009
    how to unlock keys???
    President:
  • 331 Answers
Boyz, your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computer stops and generates this fault code. Here are the things to check; * Check the drain hose and make sure it is not plugged or inked. * Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) * Check/Clean Drain Pump Filter of foreign objects * Check for Drain Pump Failure * Check the Inlet Valve for proper shut off * Check the Pressure switch for proper operation
Posted on Aug 01, 2007
  • Tracy Farrell
    Tracy Farrell Aug 05, 2007
    Please post back with your resolution.
The pump and filter are below the waser drawer behind a pannel you must remove that pannel two screws and it is right there tight spot tough to look at sometimes gets clogged found a pencil in mine
Posted on Apr 14, 2009
Every 2 years i seem to have the same F9 problem, well the trap at the pump
catches everything left over in my kids' pocket.
to clean this trap , remove the front cover at the bottom in the center is
the pump, remove the front screw and the pump is free to move about
3" forward , put a small bucket to drain the pump in
turn counter clockwise until it comes loose.
this solves the problem for me.
thanks
Posted on Nov 13, 2008
I have a Sears Elite front loader washer Model Number 110.42832 200 that I purchased in July 2002 from Sears. In July 2007 (2 months ago), the Sears guy came and did a maintenance tune up as per the extended warranty. I had not been having any problems; the tune up was free and was part of the extended warranty program. Since his visit I am having F09 error problems. I opened the front kick panel and opened the circular white plastic door with the handle to check for debris. Water came pouring out. I did not find any debris but ran the item under the faucet and replaced it securely. I ran the washer using the drain and spin mode to end the cycle. I keep having the same problem with the F09 error message coming up and the cycle stopping. I again opened the drain door to let the water pour out and did the drain and spin routine. I have used Tide HE detergent for the past 5 years. I have not moved the unit. And it was recently serviced. Last week I had a SUD error and so I ran it with no detergent etc and then the F09 error message came up. I have the manual and I have read the messages saying to check this and check that but I really have no clue how to check the pressure switch etc. I might do 1 load of laundry a week or 2 over the past 5 years so it hasn't been used excessively, I believe. I appreciate any suggestions you might have. Thank you.
Posted on Sep 21, 2007
  • luthy Sep 21, 2007
    Sorry that was my post about running the test cycle. I did not have cookies enabled.
    Novelist:
    Scholar:
  • 84 Answers
Are you using HE rated detergent? You MUST use HE (high efficiency) rated detergent in this washer. Your washer uses less water than traditional machines. With less water, the wash action can create too much sudsing when regular detergent is used. The lack of HE use will also cause the machine to use a greater amount of water and cause your error code F09.
With my machine, I cleaned out out the trap (yuck!), and then had to replace the pump when I was getting a F3 code, just 2 weeks ago. NOW, i'm getting the F9 code intermittently since then. What do I need to check now and where is it???
Posted on Dec 08, 2011
Make sure your drain hose is not too far down , yor need a gap of air same thing happened to me , wasnt draining properly it worked. also run 3 cycles empty then drain and spin
Posted on Oct 18, 2007
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load - Code F 32 - Cannot open door
F32 is the code for Pressure Switch Failure. Which is only found on a tech computer. Remove the top panel from the washer by removing the three screws in the top back of the washer. Inside the back right corner is a round plastic box, either black or white, that is the pressure switch box. Check to make sure all the quick connect wires are connected and tight. Unplug washer to reset it. If the cycle fails still with the F32, you'll need to get a new Pressure switch box. If that doesn't fix it then it could be the control box( the bigger rectangular box in the front right that the wires connect to.) Good Luck and Happy Washing
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help anyone. Machine will only start for the first minute
F/05 Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. Check the Water Temperature Sensor, Heating Element and Element Relay Check connections to the Sensor, Heating Element and Relay Hope this is helpful.
Sep 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
6,261 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
