Question about Philips GOGEAR SA6045 MP3 Player
Please HELP! Hi- I have a Philips GoGear 4GB MP3 player. I have a USB cord that i plug in to the computer to charge it, so I plugged it in and the player froze. The screen is still stuck on the charging screen even after i unplugged it. I don't know how to fix it but i was hoping you could help me cuz i really love it. Thanks!
  • 2 more comments
  • jposton13 Feb 01, 2009
    MY SCREEN IS STUCK ON THE NOW PLAYING
  • private2345 Feb 02, 2009
    ok i tried that already but once i plug the player into the computer it says do not disconnect and even when i do disconnect it it is still stuck like that until i press the reset button. the computer won't even recognize that i plugged it in in order to update it.
  • V Mom Feb 05, 2009
    While plugged in to the computer charging, it alternates messeages "Do not disconnect! and OK to disconnect! " After disconnecting it it reads File System Error then it turns to black screen. Then turning it on, it reads Philips then file system error then dead again. This is the 8BG model SA3285/37
  • shirley_vang Feb 08, 2009
    my Philips mp3 player is not showing on my computer, the folders are not showing, i can't add any new songs or pictures, how do i fix that??
If solution 1# does not not work try this then attempt solution 1#, I had the exact same problem solution 1# did not work until I did this first. Do a quick format on the player by right clicking the drive(drive J: for example) in my computer, and choose format, then check the box that says quick format. After this your player should be fully functional, but nonetheless follow the instructions to repair it completely as stated in solution 1#
Posted on Mar 11, 2009
  • 8,596 Answers
Go to www.usasupport.philips.com
Enter your model # in the search bar
Go to the page for your model #
Click on the Software & Drivers link
Download the latest version of the Philips Deivce Manager
Open the Philips Device Manager
Click on the Update tab
-Tha Mp3 Doctor
Posted on Feb 01, 2009
  • Corey Knoettgen
    Corey Knoettgen Feb 03, 2009
    Triple Reset for Philips’ GoGear:
    Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
    After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
    -Tha Mp3 Doctor
How do I download songs from my computer to my Philips gogear 4gb?
By using sync in windows media player when the player is plugged in to usb port
Dec 13, 2014 | Philips GoGear Flash MP3 Player
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
How do i put pictures on phillips go gear vibe 4Gb mp3 player?
hi my philips gogear 4gb vibe wont download pictures off my computer. but when my daughter plugs up her new ipod, it downloads them. can you please tell me why this is and how i caqn get pictures on mine? thanks
Feb 04, 2010 | Philips GoGear SA178 MP3 Player
Error message File System Error
Whenever I go to turn on my Philips Gogear audio video mp3 player, it shows the welcome screen but it doesn't go to the GoGear or the updating screens. Also, whenever I plug it into my computer through the USB cord, the charging screen doesn't show and it does not show that it is connected on 'My Computer'
Aug 20, 2009 | Philips GoGear SA3125/37 MP3 Player
My Philips GoGear 4GB MP3 player froze up and will not come back.
well if your Philips MP3 GoGear freezes up. find somthing small enough to fit in the reset hole and push it in until it shuts down.if ur light shuts off but is still froze on the same screen hold the power button and it wiil power down all the way.l then turn your gogear on and it will be ready to go TRUST ME I JUST DID IT...HAHAHA
Jul 28, 2009 | Philips GOGEAR SA6045 MP3 Player
Freezes
You have to go to Philips website and upgrade the firmware to resolve the freezing issue.
Feb 18, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips 4gb (Go Gear) mp3 player
Runa repair in Philips Device Manager
Sep 21, 2008 | Philips GOGEAR SA6045 MP3 Player
Not working.
I have no charge in my philips hdd82 player. Usually I just plug it into my computer via usb and a screen shows up on the player showing its connected and it charges. Usually it comes up as an MTP device on the computer so I can add mp3s as well. Now for no reason at all, when I plug it in, it doesn't charge and the computer doesn't recognize it. The screen shows an outlet when I plug it in so I know the cord works. It just won't let me do anything. When I press the on button with the cord unplugged, I can't do anything either b/c no charge. HELP. plz.
Nov 16, 2007 | Philips HDD082 MP3 Player
I have a GoGear device that won't charge
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Oct 03, 2007 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
314 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
