Strip on right side of screen
My computer is an Acer Aspire 5000 series. I have a problem with the screen. There is a vertical strip going along the right side of the screen that is about 1" wide and 1" from the edge of the screen. When I bought the computer, it was working fine. After a while though, it came up with this screen and the screen had this problem on and off for a while until finally it stayed on even through i rebooted the system a couple of times. I was wondering if it would be a problem with the screen itself or if it would be a problem with the software. The strip has been on the computer continuously for about 3 years. I am confident it is not a problem with screen problems such as an accidental drop or anything like that. Thank you for your time.
  • jhnswingle Feb 01, 2009
    Yes it does have a VGA adapter in the back and i have used it in the past to connect to another monitor. It worked great but the problem remained on the laptop monitor only.
  • 65 Answers
Its most likely a hardware issue...
Either the monitor is going bad or the video card is going bad. Ive seen software do some odd things but usually it was because the hardware wasnt within tolerances. If you have a way to test the monitor on another system or test another monitor on that system that would be the only really good test to figure out where the problem is coming from. Hope this helps!
Posted on Feb 01, 2009
  • Brian Feb 01, 2009
    Im sorry I just realized this was a laptop problem. However the possible problems are the same the testing procedure is going to be different. Can you tell me if the laptop has a vga connector on the back on it?
    Its most likely the lcd screen or you might even check the connection from the lcd screen to the mainboard of the laptop.
Where is the WLAN switch on the Acer EXTENSA 52325
i Found this on product manual..hope this helps.
ACER
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire 5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa 2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
Sep 09, 2011 | Acer Aspire 5100 Notebook
White screen with vertical and horizontal display problem
This the problem related with LCD. Horizontal and vertical line occur, the cause of LCD data strip disconnected. If you are able to open the LCD bezel and back cover then look display data strip that is connect with LCD. if you need more then hit me mail,I'll be online on fixya.
Aug 06, 2011 | Dell Inspiron 5000 Notebook
HI WHICH KEY DO I USE FOR THE WIFI SWITCH ON AND OFF.FOR THE ACER ASPIRE ONE NETBOOK?
Thank you for choosing FixYa
How to Turn on/off wireless switch of ACER laptops:
Aspire 3500 -
Hope this help!!!
Apr 10, 2011 | Computers & Internet
Can't Turn On WiFi
Hi Theresa
Try this.
Aspire 3500 -
Aspire
Extensa
If this will still not turn the switch on, try to go to the network connection / network and sharing center. right click on wirless network connection and click diagnose,
then it will prompt you to turn on the switch. Just click on "turn switch on" then windows will ne the one who will on the wireless switch.
Sep 17, 2010 | Acer Computers & Internet
Vertical strip on the screen
You have failing T-CON board which is part of the LCD panel assembly, it will get worst with more lines, new panel will be needed. You can try reseating the ribbon cable on the T-CON board.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 16, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
How do i remove my bezel from my 6920 acer aspire i have found 6 screws is there another 1 under the acer logo?
Actually there is more than that. There are 9 screws you have to remove. You have to remove the plastic strip under the LCD Bezel, also.
1)Four at the top. One in each corner, two in the middle. (On each side of that stretched out V shape)
2)One in each corner of the LCD Bezel at the bottom.
3) Three along the strip at the bottom.
One in the middle.
One in each corner, right next to the hinge on the inside.
The three screws from that plastic strip at the bottom, also go through the LCD Bezel.
Dec 26, 2009 | Acer Aspire 6920 Notebook PC
Acer 5100
There is a strip of plastic above the keyboard you have to pull off to get at the screws for the keyboard.
I would remove any screws under the laptop that go into the strip above the keyboard and any screws that are under the keyboard.
Then carefully pry the strip above the keyboard up with your hands or use a small flathead screwdriver along the edge.
Hope this helps!
Dec 24, 2007 | Acer Aspire 5100-3357 Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
