Question about Denon AVR-2807 Receiver
Powering On Problem
First time installation of Denon AVR-888>>>> When powering on receiver the receiver will jump start into protection mode and then shut off within five to seven seconds. How can i solve this issue?????
  • 119 Answers
Out of the box if this unit is doind this it needs repair, the other things youcan try is check all spkr connections, if good make sure the 2nd zone audio level is down to about -60
Posted on Feb 25, 2009
Why do i have to power on and off my times with my denon receiver before it connects/
That is called the protection mode, Because of a internal problem with the amp, That is causeing it to over heat, End shut down,
Dec 02, 2012 | Denon AVR-1907 Receiver
I have a Denon AVR 1601 that cut out in the middle of a song. It will now not turn on, it starts and then cuts out
It went into what is called the protection mode,Did you have it cranked up loud when it happened,? Check if any of your speaker wires come off some how end are crossing . Or there could of been a power suge that will also cause it to go into the protect mode, End fried internal parts on it.If it is a internal problem. The repairs will be verry expensive if it can be (Repaired) A lot of times it is cheaper just to go end buy a different one.
Oct 20, 2012 | Denon AVR-1601 Receiver
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Denon avr-3805 suddenly picture went out on tv (says no signal). Denon shows 'voff' on the screen. I cant figure out what happened.
I called customer support and they had not heard of this problem, and could not even tell me what the "V.Off" showing on the display represents. But, . . . the problem was solved by resetting the memory - by powering off, and powering back on while holding down both the Mode and Analog input buttons. Although this wiped out all my settings, the "V.Off" on the display disappeared, and the video now works. Problem solved.
Feb 14, 2011 | Denon AVR-2805 Receiver
Can i hook up two subwoofers to a denon avr 1907
Sure, just get an RCA splitter and share the Sub Pre-Out with the two self-powered subs or one amp powering two of them.
http://www.retrevo.com/support/Denon-AVR-1907-Receivers-manual/id/696ci072/t/2/
Dec 28, 2010 | Denon AVR-1907 Receiver
My Denon is in Protect mode, what can I do to change this back to normal mode. I do not have the remote control either?
First, disconnect all speaker wires at the receiver and turn it back on. If it stays on, your receiver is ok and you need to check each wire and each speaker by re-connecting them one by one and re powering the receiver. You will either fix the problem or find the problem by doing this. It's either a bad speaker or a wire is shorted in line or at the receiver or speaker. It's the most common problem of all. If your receiver still shuts down, it needs to be serviced. Hope this helps
Sep 23, 2009 | Denon AVR-1804 Receiver
Avr 688 shuts down immediately after powering on
Internal problem with power supply or one of the channels. Bring it to a repair facility.
Aug 09, 2009 | Denon AVR-685 6.1 Channels Receiver
Ipod connected to denon 888 not playing music
Make sure your ipods tv out option is set to the on option from the menu and that you are sure you are on the correct input on the reciever.
Jul 25, 2009 | Denon AVR-2805 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Denon AVR-2807 Receiver Logo
228 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
