Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Almost new McCulloch 7800 won't start.
Decided to pull the generator out today and fire it up. It is basically new and has only been run once for two hours. Pulled the plug and checked it (looked great). Turned the fuel on and pushed the electric start. Would turn over and over but would not fire up. First checked the fuel line and went so far as to blow the whole thing out. Pulled the plug again and squirted some gas into the cylinder. Hit the starter again and it fired up for a few seconds. Appears I am not getting fuel into the engine.
So any ideas as to what to go after first before I start taking things apart. Thanks!
  • Anonymous Feb 01, 2009
    I thank you for answering my question so quickly. Hey I haven't worked on a carbureted car since high school (30 years). I did pull the carb off the intake just to see if anything obvious stood out. Nothing did and I tipped it to make sure there was indeed fuel in the carb. So with that where is the needle I am looking for in the carb. Thanks again, Kevin
  • Thomas F. Schneider May 11, 2010
    The carburator float bowl first. See if the needle is stuck shut along with the float in the up position.
    Novelist:
  • 152 Answers
This is a typical problem with small engines that are not used often or only used seasonally
The problem exist when it is not prepped for storage properly, meaning that the fuel is not shut off and the engine allowed to burn off the remaining fuel that's left in the carburetors float bowl, causing the un-spent fuel to sour and later creating a condition called varnishing which clogs the carburetor venteries
All of these steps will require the use of skin and eye protection!!!
The solution is to replace the old fuel in the tank with fresh, its not a bad idea to replace the fuel filter at this time, then with the petcock in the off position remove the carburetor float bowl, inspect the gasket or seal for imperfections (replace as needed) and clean it along with the float assy. and piston check valve with a spray type carburetor & choke cleaner and gently wiping with a clean lint free cloth so as to remove all yellowish colored varnish and any debris, before reassembly place a glass or metal catch pan or bowl under the carburetor and turn the petcock to the on position to allow fresh fuel to flush out the fuel line and now LIGHTLY & GENTLY (without resistence) lift the float up, the fuel should stop flowing. If it does not stop, repeat cleaning procedure. If it does turn the petcock to off and reassemble. After reassembly turn the petcock to on, the engine should run.
Another preventive step is the use of a product called STA-BIL fuel stabilizer
Posted on Feb 20, 2009
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
Oct 01, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
McColloch 7800 generator leaking fuel from the carborator.
rebuild carb using new needle and float if float is full of gas and sinking
Sep 17, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
My new McCulloch MAC842 will not start, the on/off and choke switches do not move, any answers please.
It should work that as you pull the choke pull out it also swithes the ignition on, you should see the red switch lift up as the choke is pulled out, once the engine fires you then just push the choke in, it will not run with the cheoke out , only fire once.
Mar 04, 2012 | McCulloch Garden
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Powerboss 6500 won't run tools
powerboss generator wont start,,fresh fuel,fire to plug,clean float bowl,,,,,,honda gtx 390 motor,,,,13 hp,,,help
Oct 14, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 5700, 11 HP Starts easy with 2 pulls and begins running fine. Then it start dying and back fires,revs up and down, back fires. Then will run normal for a few minutes and will start revving up...
Sounds like you may have a wire shorting out. Check all ign wires and make sure one hasnt rubbed through. Maybe take off your front cover and make sure something isnt shorting out your coil contacts. Hope this helps
Nov 02, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 32cc backpack leaf-blower
Mcculloch MB3202 anti-vibration back pack leaf blower, runs better at the middle setting of the choke than it does if it's wide open the way it should be. Can't get it to blow leaves well. Owners manual lost. ANY ADVICE???????? New gas, spark plug starts on the first pull but just doesn't give out like it should.
Nov 07, 2008 | McCulloch 26cc Backpack Blower with Dual...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
409 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
