I have to use the function key every time i want to use a letter or number that has a dual function key how do i turn it off
  • 79 Answers
Try Fn+Num Lk or
Fn+F11 or
Fn+Scr Lk
Posted on Feb 01, 2009
Making words with letters
Do you mean "numbers" with letters?
If yes, please check the number lock key is not turn on and if it is so you need to turn off it.
You can locate number lock key with one of the function keys depending on the make and model of the computer.
To turn it on / off you might need to use "Fn" key that again depends on the make and model of the computer.
To identify, you need to check any of the function keys, what is printed in white color, F1, F2... so on or the image. whatever matches with the color of "Fn" key, that function can only be used while holding "Fn" key and pressing the particular Function key.
Jul 14, 2014 | Computers & Internet
When I type letter keys, numbers come up with the letters
That's because some are dual function keys; you've probably hit the 'Alt' or 'Fn' key to the bottom left of the keyboard by accident. If you look carefully at the letter keys, they should have numbers on them in a different colour/smaller text.
Jun 25, 2014 | Toshiba Satellite A105 Notebook
Samsung N130 keyboard not typing some letters and other letters type numbers
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Apr 20, 2013 | Samsung NP-N130-JA01US Netbook
Some of my letters are not working
If numbers are appearing instead of letters then -
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Sep 03, 2012 | Toshiba Computers & Internet
Above my scroll/# lock the lightbar is lit,and some letters produce #... i = 5 etc
Sounds like yo have the scroll lock or num lock turned on. If the scroll key is a colored key (the scroll lk lettering is blue) then you will have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the scroll key to turn it off. When it is turned on if you press the letter i you get the number 5. If you press the letter O you get the number 6.
Notice that the numbers on the keys that have letters are a different color than the letters (blue most times). That means you have to Press and Hold the blue FN function key at the lower left portion of the keyboard then hit the key with the same color if you want the colored representation to happen.
Some laptops will use a Square Box instead of the blue colors on the keys. In that case you have to press and hold the key a the lower left portion of the keyboard that has the square box, then hit the key you want.
Jun 03, 2012 | HP Compaq Presario C500t Notebook
On my laptop when pressing letter L shows number 3... rest of the letters that have number
You must had accidentaly turn on your numlock function.
To turn this off find the key that looks lika lock with a number in it or a word numlck.
Press that together with your Fn key.
Good day.
Jun 20, 2011 | ASUS Computers & Internet
My laptop is only typing the numbers that appear on the letter keys. For example when I hit the letter J, it types a number 1. When I hit the letter k key, it types a 2, etc. How do I get it to go back...
Usually you have to hold the "Fn" key to get to these. Look for a "NumLock" key to turn this off. You may need to use the "Fn" key to select numlock.
Mar 10, 2011 | Computers & Internet
The keyboard on my ACER Aspire is stuck in a mode...
Find the key that says num lock, press the Fn key and the num lock key to turn off the number lock.
Jun 16, 2009 | Acer Aspire 3000 Notebook
Keyboard problem
Press the FN (Function)key and the NmLk (Number lock) key at the same time.
May 08, 2009 | Samsung NC10-14GW Notebook
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Mar 27, 2009 | Uniden BC246T Handheld Scanner
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
