Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener will not open or close with remotes
My wall unit red light is constantly blinking
    President:
  • 2,976 Answers
Put new batteries in the remotes.
Check the DIP switches in the opener
Check the dip switches in the remotes. They must match the opener.
Posted on Feb 01, 2009
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
I have a liftmaster Model 1240. Door will open by remote or wall opener. The door will only close while holding wall opener button down. If i try and close via remote, light starts blinking and door...
The only thing that will cause the main light to flash 10 times and the door to reverse to the open position is a sensor problem. Make sure the light on each sensor is on and not flickering ever so slightly. Make sure they are not moving when the door starts to close. Lights on sensors should not blink. One light should stay on constantly and the other sensors light should go off when you block the sensors.
Jan 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
The green light on the wall switch is blinking constantly yet it works to open/close the door. The remote does not work. Any suggestions?
Press and hold the lock button on the wall control for 3 seconds. The light will stop blinking and your remotes will work.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
My red light sensor is blinking constantly and the green light sensor is steady. I grab hold of the red light sensor and squeeze and the light goes solid and I am able to close the garage door. when i let...
It sounds like there might be a loose wire connection on the inside of the sensor. You could also be moving the position of the sensor slightly into alignment when you squeeze the sensor. You will need to disconnect the wires for the sensor on the garage door opener or disconnect the power. Then use a flatblade screw driver and carefully seperate the sensor case. Check for any loose connections on the wiring(you might need to re-solder the wire to the sensor eye). It sounds like a loose wire connection to me.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
224 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
