Question about Canon i9100 InkJet Photo Printer
Canon i9100 Printer - damaged carriage ribbon cable
I can not find a replacement 'carriage ribbon cable' for my i9100 printer, there are three cables as one, the longest one kinked near the carriage end and became U/S. the printer was working properly until this happened.
Do you know where I could purchase a cable assembly.
Regards, Russell Zammit.
    President:
  • 2,692 Answers
Contact Canon support by E-mail. Or Solution: Ordering parts for your product
Ordering Replacement PartsCanon does not sell internal replacement parts on-line. Parts are available exclusively by calling the Canon customer support center (the contact information is listed below).
However genuine Canon supplies and accessories are available for purchase on-line at the Canon eStore. Before calling Canon, please check the Canon eStore to ensure that the item you need is not an accessory that is available in our on-line store.
To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
For your information, below are examples of what constitutes an internal part Vs. a supply / accessory:
Examples of Parts:
  • Print Heads
  • Printer Paper Trays
  • Printer Paper Guides
  • Camera Battery Doors
  • Parts Only Assessable By Taking the Product Apart
Examples of Supplies / Accessories:
  • Ink Tanks
  • Battery Packs & Chargers
  • Most Power Adapters and Connecting Cables
  • Shoulder / Neck Straps
  • Bags and Cases
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=8738#SupportDetailAct
Posted on Feb 01, 2009
When printing a job halfway through the printer makes a loud clunk then stops and throws 2F26 error
Chad, for future reference, if it costs more than 50% to repair an item than it does to buy a new one, deep six it.
I don't know how long you've had this printer for; or how much you paid for it, but at this point, you certainly made quite an investment in an attempt to repair it, with little headway.
Sounds like you went about this using the guess and check method...anyway, you went this far and invested a small fortune, and you pretty much replaced all the parts other than the belt and ribbon cable, it sounds like you want outside support to convince you to replace them...so go ahead, permission granted! :)
Mar 18, 2015 | Canon imagePROGRAF® iPF8100 InkJet Printer
Disconnected white cable
if it is a flat cable some of them had a little clip that would slide back allowing you to reattach the cable some do not
Jan 29, 2014 | Kodak ESP Office 2150 Wireless All-In-One...
Trailing cable burns
The smoking and melting cable are the result of a short cicuit.
The problem is going to be determining which end the short is occuring on. It most likely is the carriage end of the cable that is the culprit. Most likely you will need to replace the carriage assembly and of course the trailing cable as the new one may have also been damaged.
You may need to use your fingers to check if the top of the carriage assembly (where the cable connects) is also getting hot (warmer than normal).
C7769 60376 DesignJet 500 800 Print head carriage assembly C7769 69376... Trailing Cable for HP DesignJet Plotters Wide Format Printers
Jan 29, 2014 | HP DesignJet 500 InkJet Printer
Canon ip 2770/2772 Printer error B200 slover
Solution 1:
Disconnect the power cable from the printer.
Wait 1 hour.
Connect the power cable
Solution 2:
Check and Clean Head contact pin condition of the carriage unit
Check Cable connection especially the carriage FFC
Solution 3:
Replace the Printhead
Solution 4:
Replace the power supply unit.
Solution 5:
Replace the logic board.
Dec 19, 2012 | Office Equipment & Supplies
Hi There. I have Tally T2265 Serial Matrix Printer. It shows "Hardware Alarm & Check Ribbon Error" after printing 2 or 3 pages. Sometime it prints 7-8 pages and sometime it prints 2-3lines...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Before suspecting other components check the printer model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribbon should be 062471.
If the correct ribbon is used the problem could be the timing strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be caused by the timing station on the carriage, the carriage motor.
Mar 10, 2011 | TallyGenicom 2280 Matrix Printer
Hi my Tally printer giving an error Pw Sensor defekt plz advice me
You are seeing the "PW Sensor Defect Error" because the printer is detecting a fault with the Paper Width Sensor.
The Paper Width Sensor is located on the print head carriage and detects the paper edge to prevent printing on the platen.
You can check the follwoing;
  • Ensure the print head cable is not damaged and makes good contact with the printer and print head carriage
  • Ensure the Paper Width Sensor is connected correctly to the print head carriage assembly
  • It may be necessary to replace the Paper Width Sensor
Mar 09, 2011 | TallyGenicom 2280 Matrix Printer
I cannot remove this error message: Remove and check cartridge on right. I have removed and replaced the cartridge, reset and disconnected the printer, but nothing will make it go away. I cannot print...
I had similar problem with my 7310. Suggest removing the cartridge and inspecting the carriage. Look for a metal spring that may be dislodged. Mine was due to a little plastic tab that broke. This spring makes contact with the flex ribbon cable and being dislodged prevents contact. If you're lucky, you'll just have to put it back in place. I had to use some quikplastic to repair the carriage. My repair how to is at http://www.fixyourownprinter.com/forums/inkjet/46650 posted 10/28/10
Also inspect the flex/ribbon cable. Many people have found it damaged, presumably from the spring. If that's the case, then you'll have to replace it.
Good luck
Nov 17, 2010 | HP Officejet 6500 Wireless All-in-One...
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Canon Hardware Error 03130031-2F26
hi
2F26 is a carriage error,you can solve your problem if you update your firmware version to 1.35
if your printer firmware is 1.32 and below. try this link http://software.canon-europe.com/software/0027485.asp?model= follow the instruction included
Nov 12, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon i9100 InkJet Photo Printer Logo
161 people viewed this question
old marine
old marine
