Question about Lexmark X2470 All-In-One InkJet Printer
Lexmark printer x6570 unable to allign after putting in new cartr
I just install black cartridge in my lexmark x6570 printer and only half the test page is printing, i check the paper that is ok, i took both carridge out re try....nothing seems to work
  • Brian May 11, 2010
    when you say half the page is it missing colors? top half? bottom half? right half? left half?
  • Lexmark Master
  • 684 Answers
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Good Luck
Posted on Feb 01, 2009
Lexmark x6570 print black on colour cartridge
In your control panel, devices and printers, click on your printer. you can make it print black from there
Apr 04, 2012 | Lexmark X6570 InkJet Printer
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
My lexmark 1150 won't print and I've lost cd and don't have the manual book. Would it have any thing to do with because I put in ink cartridges 17 and 27 and it requires 16 and 26 ink cartridges.
It works with both 16 and 17 for Black and 26 and 27 for Color.
Go to the Panel from Lexmark X1100 series- Series Solution Center and select the new type of cartridges. Allign the cartridges, make an excel test with 4 colors(cyan, magenta, yellow, black) and it should work
If you need further assistance, do not forget to post and don't forget to rate.
Thank you
Feb 27, 2010 | Lexmark X1150 All-In-One InkJet Printer
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
Ink cartridge
Using some switch cleaner solvent, gently clean the contacts on the cartridge carriage, and also if you have any, use some inkjet cleaner to clean the nozzle where the cartridge sits, this should clean the mechanism sufficiently to allow the printer to detect the cartridge.
Mar 05, 2009 | Epson RX595 Photo All-In-One Printer
Hi I have a lexmark x1180 and have just installed new cartridges however when printing text it is printing two of the same very close together (so it looks like double vision) also when trying to print...
It sounds like your cartridges should be alligned. In your Lexmark 1180 Program Group (Start->All Programs->Lexmark 1180) there should be a Lexmark Solution Center or Lexmark Productivity Studio.
If Lexmark Solution Center - go to the maintenance tab and run the alignment process.
If Lexmark Productivity Studio - click on Printer Maintenance and then select Align
Sep 11, 2008 | Lexmark Office Equipment & Supplies
Refill cartridge for lexmark X6570
please note that I am not an expert, in this field just an attorney and that is why I am putting my full disclaimer right here at the top---That i am not an expert but only speaking from experience.
Earlier this morning, I just pulled the cartridges to check the Lexmark print (X6570) cartridge numbers (41&42). When I typed these numbers in on to retrieve the price and other information for these cartridges, they did not have any refill kits or anything of that nature for these specific cartridges.
To answer your question about why the printer is not detecting that your cartridge is full is probably because the cartridge has a chip in it that essentially disables it once the original manufacturer ink is empty. tHEY [Lexmark & Dell] do not want outside competition In other words, the printer manufacturers make the bulk of the money on selling new cartridges (for a fortune) . To make matters worse, they always seem to be half empty even though they are ‘brand-new’ ink cartridges The bottom line is that the faster you can go through a printer cartridge, they can sell many more of the cartridges that they are charging us a fortune for.
Needless to say, I am just going to go and get me another HP printer. My advice would be to check to see if ink-refill kits (see sites like are available for any future printers that u purchase.
Sep 05, 2008 | Lexmark X6570 InkJet Printer
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Nov 08, 2007 | Lexmark Inkjet Z517 Photo Printer
Lexmark X2470 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
