Question about Juki DNU-1541 Mechanical Sewing Machine
How to attach thread assembly
There where no instructions on how/where to attach the thread assembly on this machine. Brand new to industrial machines. Any help would be much appreciated.
Thank you.
Loria'
  • 46 Answers
Hi, can you please be a little more specific, if you are refering to the thread stand it is placed on the top right hand corner of the bench top.
Posted on Aug 22, 2009
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
Needle will not pick up bobbin thread
Try installing a brand new needle. Rethread the machine from the very beginning. The machine could be out of time, ie the needle and hook timing do not match.
Nov 18, 2015 | Singer Sewing Machines
I need a manual for a JCPenney Model 6601. Or at least how to thread it.
Back in my 7th grade home ec class (I'm 52 yo now), our teacher told us that all machines thread basically the same and I never forgot that and it has served me well through the years. No matter what brand of machine, or level of machine (from little girls first one, my embroidery or my heavy duty industrial leather machine) they have all threaded the same:
Thread spool
thread guide
thread guide
tension
take up lever
thread guide
thread guide
needle
(the number of thread guides may vary)
Best of luck and happy sewing!
Dec 13, 2014 | Sewing Machines
My juki 8700 h frays thread while trying to sew
Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
Mar 26, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Industrial over locker
The singer site would be a good place to start. There are also groups on Facebook that you can ask a lot of questions about industrial machines.
Oct 02, 2017 | Sewing Machines
I am having trouble threading my singer industrial sewing machine I can't remember how
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.Your Industrial machine has a long groove on one side of the needle. This long groove must be on the left side of the needle when it is inserted properly.
sewman7
Jun 25, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
124 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
