Question about Microsoft HP Pavilion DV6276US Notebook PC
My HP Notebook first showed a black screen and then after a hard shutdown and restart it only shows a black screen with colored lines. It seems that it is starting up even though I can't see the screen.
  • 2,559 Answers
Try this,Start in VGA mode.Once started,update your video drivers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Posted on Feb 11, 2009
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
'' a problem has been detected and windows has shutdown to prevent damage''
From the description it is the hard drive that is the problem, format the whole hardware and re-install your xp windows to see if that will clear up the problem, if not! have the hard drive tested to see if it must be replaced.
May 02, 2012 | HP Pavilion dv4000 Notebook
Hello. I'm new to the forums, and now, almost every time i shut my laptop down, it just becomes a black screen. It doesn't use the hard drive (or at least that's what the hard drive led shows, it turns... and instal the hotfix file through pendrive(download the file from website).
2.after the downloading put the file to pendrive and restart your system and the file automatically installed.
Nov 17, 2010 | Dell Inspiron 710m Notebook
White screen with black vertical hypen lines???
Hi, you should get an update for your graphics driver and the Bios update. After the updates for the driver. Do a hard reset. To do a hard reset. We need to shutdown the notebook. Remove the battery. Remove the power cord. Press and hold the power button for 30 seconds. Do not expect the turn on. That would be weird. Actually we are trying to reset something internally. After this. Test if the issue goes away. Hope this helps!
Mar 04, 2010 | Compaq Presario M2000 Notebook
Black screen with vertical lines through it
Could be faulty graphics chip or faulty screen. If you can hook up external monitor and picture is fine then probably faulty screen. If external monitor shows same problem the faulty graphics chip. Take to repair shop and let them have a look.
Jun 10, 2009 | Compaq Presario M2000 Notebook
Dell Latitude D620 Nvidia Quadro NVS 100m
Suspected it's a graphic error. Try re-installing your video driver to it's later version.
May 30, 2009 | Dell Latitude D620 Notebook
I have hp pavilion dv6000 i had a problem about recovery manager
Did you attempt to load recovery/factory image from hidden partition and if so did you follow User Manual or Guide re instruvtions? if so there should have been no problems. I would try again though do it slowly and carefully when choosing Options so that you don't change Partitions where the Default Software is.
Was it Alt and F10 buttons when powering up from a Shutdown, i.e Cold Boot?
Apr 09, 2009 | HP Pavilion dv2000t Notebook
My XPS 1530 will not shutdown, it only restarts
Try running chkdsk /r and then restart the computer. to do that, click on START, RUN, in the open field, type 'cmd' and press <enter>. A dos window will open. At the blinking cursor, type 'chkdsk /r' and press <enter>. You will get a message that the drive can't be locked and do you want to run it the next time Windows starts. Type 'y' and press <enter>. Now shutdown the computerand restart it. Chkdsk will run and it may take some time. Depending on your installation, you will see a blue screen that will show the progress. Sometimes the screen will stay black and the hard drive light will flash. That's ok. Let it run until Windows loads. Wait until it is completely loaded and then try shutting it down normally.
Good luck and let me know how it works out.
Feb 07, 2009 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Microsoft HP Pavilion DV6276US Notebook PC Logo
160 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
