Question about SanDisk Sansa e250 MP3 Player
Sansa e250 i downloaded some short film from atomfilms anyway so i download them to the computer in zip format then i extracted them and it was made in to a quicktime file so i put it into the converter that comes with the sansa one out of like six actually played on the sansa. i thought maybe it could have been the option in wich i downloaded it because atomfilms gives you 3 options in witch to download the film 1)pc download 2)ipod download 3)psp download so i try both pc and ipod and i dont get a dam thing on the player do you know what the deal is?
    Problem Solver:
  • 7 Answers
You may need to download a different file converter and convert the quicktime files to wmv files and then use the sansa converter to put them on the mp3 player.
Posted on Aug 09, 2007
SOURCE:
I am trying to download films onto my sansa fuse 8gb??
You need to use the Sansa Media Converter to convert videos (and photos) to a format the Sansa can handle.
Dec 29, 2009 | SanDisk Sansa Fuze MP3 Player
I can't update my sansa e250 mp-player
Does just going into computer right click drive and then quick format help. Not positive on that one.
Nov 13, 2009 | SanDisk Sansa e250 MP3 Player
Cannot install rockbox on my sansa e250
did you extract rockbox...........did you patch it you need this also (DOWNLOAD THIS FROM HERE) http://download.rockbox.org/bootloader/sandisk-sansa/sansapatcher/win32/sansapatcher.exe
once you do this plug device to pc...copy what was extracted and paste to root of the device
installation link http://download.rockbox.org/manual/rockbox-sansae200/rockbox-buildch2.html#x4-60002
manual http://download.rockbox.org/manual/rockbox-sansae200/rockbox-build.html
have fun rock with the box
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Formatting a Sansa e250
Plug it in, open "My Computer" right click your device and click "Format" a window will pop up with the settings on how you want to format it, make sure it's set to FAT, then click "Format."
Hope this helps!
Oct 13, 2008 | SanDisk Sansa e250 MP3 Player
ITunes and E250
if you install the media converter that came with it then i believe so
Jan 29, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
You need to use the Sansa Media converter. It was on the installation disk. If not, you can get it here; http://www.sandiskthailand.com/images/SansaMediaConverter.zip Best of Luck.
Sep 21, 2007 | SanDisk Sansa e250 MP3 Player
No more music
- As with nearly ALL sansa e250 problems, formating it will bring it back to normal. 1. Connect it to your computer. 2. Open 'My Computer' and right-click the device. 3. choose 'format...' and then 'quick format'. 4. If you haven't done so, upgrade the firmware: -Find the firmware on the Sandisk home page. Don't use the wrong one, though. If you have a Rhapsody version, choose the e200r player. Download the .zip file and extract its contents (right-click, 'extract all'). Then connect your player to your computer and drag the extracted file to your player's drive. Now when you turn your player on, it'll undergo the firmware update. You can also update your firmware by connecting to Rhapsody with your player hooked up and following the firmware update instructions when the window comes up. If the firmware update window doesn't appear, then you have the latest firmware to date. 5. Test out the player and see if this method worked. If not, you may want to send it back sandisk or return to the retailer you bought it from.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
Hello. Seems like your player is encountering either a file or system error, causing it to freeze. One solution would be to see if your player would be detected by your PC, then attempt to format it. Another solution would be to re-apply the firmware. Here are the steps: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
How do I format my Sansa e250?
This worked for me... Hope it works for you as well
*Disconnect the device, turn it on
*Go to Settings > USB Mode > MSC
*Connect the device
* Open up My Computer
*Under the heading "Devices with Removable Storage"
Look for Sansa E250 (Removable Drive) - Note: this heading
"Devices with Removable Storage" applies to the "Arrange Icon By: Type" , option in My Computer Window
* Right-click on the E250 and choose format
*Click "Start" and agree to the format
Jan 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
