Question about Polaroid 3211TLXB 32 in. LCD Television
WHAT DO i NEED TO DO
MY TV SCREEN IS CRACKED AND i DONT HAVE WARRANTY WHO DO i CALL AND WILL IT BE EXPENSIVE?
HAVE YOU TRIED CALLING THE MANUFACTURER?
Posted on Jul 31, 2007
I accidentally knocked over my TV and I was wondering if the limited warranty would fix the TV for me damge is on the second screen
Search Results
    TV Warranties & Proper Care - Rtings.com
    www.rtings.com/tv/learn/tv-warranties-care
    Oct 2, 2015 - Vizio, 1 year, 1 year, No, Yes, ?30", 1-877-MY-VIZIO. What warrantiescover. A TV's warranty covers the product in the event of a defect in materials or workmanship. If the manufacturer agrees that there is a defect and said defect was .... linked by cnet) but was wondering if an extended warranty would be a ...
    TV Screen Cracked From The Inside ' Where To Buy? ' How ...
    removeandreplace.com/.../tv-screen-cracked-from-the-inside-can-this-be...
    Sep 24, 2015 - Check to see if you bought this warranty and if so return the TV ... Especially if your TV is under 6 months old and mounted on a wall therefore not able to be easily touched or knocked over. ... If you get no help from the TV manufacturer, then you can look into ... How do I install my new replacement screen?
    TV Repair: Can a Damaged LCD be Fixed? ยท Bright Hub ...
    https://disqus.com/home/.../tv_repair_can_a_damaged_lcd_be_fixed/
    My LCD TV started to show these bright blue lines all over it. It started doing it overnight! ... harry. same here i was wondering if it will spread or somthing ..
Jan 11, 2016 | Televison & Video
Tip
What to do when you have a cracked LCD, LED or Plasma TV
Spending a ton of money on a new TV is the norm these days. Unfortunately televisions are not made like they used to be. Flat panel LCD, LED and Plasma TVs are very fragile. The picture area can be cracked by even light objects hitting the TV.
Once the picture is cracked there is no way to repair it. It needs to be replaced. TV manufacturers purchase LCD, LED and Plasma screens in large quanities and get a great price. When your local repair shop has to purchase a single replacement unit, you will often find it is as expensive if not more expensive then a new TV (if its even avaliable) when you factor in the labor costs. Usually you are better off replacing the TV with a brand new set the next time a good sale comes up then have it repaired.
You would think the TV's warranty or extended warranty you purchased would cover a cracked screen. Alas.. they don't. Every warranty I have ever read does not cover accidental damage. As soon as the repair person sees the screen is cracked, they will tell you the warranty does not cover it and you are out of luck.
While there isn't much hope for repairing your current TV, you can take some simple steps to protect your new TV from damage.
1. Mount the TV on the wall. Its a lot harder for little kids to hit the TV or throw something at the TV when it is mounted on the wall vs sitting on a stand.
2. Explain to the family how fragile the TV is. While this might seem obvious.. kids do know things until they are taught.
3. Wear the wrist strap while playing video games as recommended!
4. Pickup a tv screen protector from a company like TV Armor. They are designed to provide impact protection for the TV without affecting the picture.
Following these simple steps can keep you enjoying your new TV for many years to come even if you do have a budding baseball player at home.
on Jan 07, 2010 | Televison & Video
Cracked screen what can i do its new
If it has any type of video out, you can at least recover any files by hooking up a monitor or TV, depending on the output. But the bad news is, if the screen is cracked, its just about as expensive to fix is it is to buy a new one. Sorry. Hopefully you had a warranty.
Nov 22, 2014 | Tablets & eReaders
Screen cracked
Unfortunately replacing a cracked screen is very expensive, I would recommend replacing your TV with a newer TV.
May 09, 2013 | Mitsubishi WD-60737 TV
Plasma t.v fell and screen cracked
Sad to say that the panel is the most expensive parts on your TV, it will cost you almost the same as a new set. Since it is less than a year, it is still under warranty period however accidental damaged will not covered by the warranty. I would advice you to contact the dealer where you bought the unit and inquire if they can do something on your problem. Cracked screen is not repairable, the only solution is to replaced it with a new one.
Jdvillanueva
Jan 13, 2012 | Sanyo Televison & Video
I have a insignia ns32-09 the screen is cracked. Wondering if I should junk the unit or replace the screen
Unfortunately your suspicions are correct in this instance.
Your tv is an ultra-budget no-name generic model, and the lcd panel is the single most expensive part of the entire tv. It would actually cost more to buy the panel alone than an entire similar quality tv which would have the advantage of a fresh manufacturer's warranty as well. .
Jun 24, 2011 | Televison & Video
LG 42" tv LCD pannels inside tv have a cracked
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
Jan 18, 2011 | LG 42LC2D 42 in. LCD HDTV
The screen has a crack in it too
If the screen is cracked, sorry to tell you but you need to replace the entire screen. If it is under warranty contact the manufacturer to find some cost effective options. Replacing the screen may be almost as expensive as buying a whole new TV of the same model.
Jun 05, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Element 32" flat screen tv has cracked screen
Sorry, but it's not worth to buy just a screen (probably you cant find just a display), so better start searching replacement tv... Take a lookon amazon or something... Amazon com TV Have a nice day
May 27, 2009 | Element ELC-HS321 32 in. LCD TV
While moving someone accidently cracked the screen-can it be replaced
It can be, but at quite the price. Screens are very expensive and can amount to 2/3rds the price of the TV. In most cases, count the warranty out, if you are still under one, unless you found a manufacturer that covers accidental damage. Do you have house insurance or accident insurance with your credit card company if you used it to buy the TV?
Sep 29, 2008 | RCA P52937 52" Rear Projection Television
Polaroid 3211TLXB 32 in. LCD Television Logo
20 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
